24" 1920x1200 pixel display
llama_thumper
microchip911
llama_thumper
Nebelfelsen
I have ordered the Dell 24-inch-screen (will arrive next week or so..).
When using an IBM X31 with ATI Radeon, will it be possible to connect the screen via DVI at a 1920x1200-resolution? The IBM-hotline says, the maximum resolution via DVI is 1260x...
Or do I need modified drivers?
The DVI-Port is available on my dock (Dock I, Type 2631) and on my old port replicator. Will it work or do I need a Dock II or a new port replicator?
If nothing helps: can I also connect the screen with the analogue-port at 1920x1200 or will it not work at this resolution?
Thanks for your help!
Nebelfelsen
I have now received the Dell 24 inch. It's great and good quality (no dead pixels).
Unfortunately, the analogue signal taken directly from the output of the X31 is very poor (not sharp). I have read, that IBM has deactivated the DVI-output on the X31 series, so a port replicator won't help.
Currently, I am running the screen on a Matrox PCI-Card in a Dock I. But the reaction of the screen ist very slow, especially when trying to watch a DVD.
Does anybody know if it is because of poor RAM (only 32 MB) in the Matrox? I wonder if it will be faster when buying a bigger PCI-card but I am not sure if the speed isn't perhaps limited by the connection between the Dock and the Thinkpad (in this case, a better graphic card won't help of course).
Nebelfelsen
I have now exchanged the Matrox card in the dock by an ATI Saphire PCI-card with 128 MB RAM, because the Matrox support said, the G450 will only support DVI with a maximum resolution of 1280x...
The new ATI has one analogue and one DVI-output. With analogue output everything works fine with a resolution of 1920x1200 @ 60 Hz. It is much faster than the old Matrox.
But when connecting the Dell screen to the DVI port and switching the resolution to 1920x1200, a synch-problem appeared and the screen went black. Nothing worked. I had to reboot and everything works fine now although it isn't possible to rotate the screen by 90 degrees when connected over DVI (the same synch problem appears then). The rotation works fine in analogue mode. Seems that in DVI mode 1920x1200@60Hz is not 100% supported...
llama_thumper
Thinkpadder
- 1 Replies
- 423 Views
Last post by rijhsing
Mon Jan 16, 2017 5:24 pm
FS: $274.99 Lenovo ThinkPad W701 17" Core i7 1920x1200 100 GB SATA 4 GB RAM Win7 x64
by rijhsing » Mon Jan 16, 2017 10:26 am » in Marketplace - Forum Members only - 16 Replies
- 1531 Views
Wed Mar 08, 2017 10:49 pm
Vertical bands on x220 ips display: is it the display or the LVDS cable?
by xserieslove » Sun Jun 25, 2017 7:41 am » in ThinkPad X200/201/220 and X300/301 Series - 5 Replies
- 183 Views
Last post by xserieslove
Mon Jun 26, 2017 12:31 am
Display dimming with PWM?
by blue42 » Thu Dec 29, 2016 6:45 pm » in ThinkPad T430/T530 and later Series - 0 Replies
- 463 Views
Last post by blue42
