Low Performance
vraa
Low Performance
#1 Post by vraa » Fri Apr 08, 2011 7:34 pm
I have a Thinkpad T410s with the discrete Nvidia nvs 3100m. It sucks, I have heard installing the 310m driver can improve performance, how can I do this?
I have updated my notebook drivers to the latest nVidia 270.51 verde driver, but performance still sucks.
I don't know what I did but in the last week performance dropped massively, I can't even run my old games (eve) which worked fine before :(
Colonel O'Neill
Re: Low Performance
#2 Post by Colonel O'Neill » Fri Apr 08, 2011 8:16 pm
If it used to work fine, then you did something wrong elsewhere. If you have the discrete (regular switchable, non-Optimus one) then you need the Lenovo provided drivers.
Try restoring to a restore point from before the issue.
vraa
Re: Low Performance
#3 Post by vraa » Sat Apr 09, 2011 8:10 pm
It is the switchable, but I disabled the Optimus, Intel sucks
I am still playing around with the drivers, not sure why they are so slow
The Lenovo provided drivers are no good
Colonel O'Neill
Re: Low Performance
#4 Post by Colonel O'Neill » Sat Apr 09, 2011 8:25 pm
I don't think the drivers are to blame unless something happened to them. You said it used to work fine. Can you System Restore to a time when it worked?
I also think you're missing the point of Optimus. You're not supposed to be using the Intel one for demanding applications.
vraa
Re: Low Performance
#5 Post by vraa » Sat Apr 09, 2011 8:38 pm
But even Windows aero is too demanding
Intel GPU is an oxymoron
Colonel O'Neill
Re: Low Performance
#6 Post by Colonel O'Neill » Sat Apr 09, 2011 8:39 pm
Uh... Aero should run more than fine on the integrated GPU. Aero runs fine on a 945 chipset.
You're doing something wrong.
Try restoring to when it worked.
vraa
Re: Low Performance
#7 Post by vraa » Sat Apr 09, 2011 9:15 pm
I have disabled system restore
I will format tonight
