Graphics Card Comparison
Colonel O'Neill
Re: Graphics Card Comparison
If you need more detailed instructions, let me know. The manual install process is a bit uncooperative at times.
I'm going to go bump the overclock thread soon with 11.4 game FPSes, including both stock and overclock speeds.
hunterman223
Sounds good. I should manage, been through the manual install process more times than countable on dozens if systems. Just knew to the switchable graphics scene. It's a very good concept.
Sent from my iPod touch using Tapatalk
Hunter Thompson
ThinkPad T400: T9400, 8GB, LG WXGA+, Samsung 830 128GB + WD Scorpio Black 500GB, Intel 5300agn, Win7 Pro x64
Others: IBM ThinkPad R40, Sony VAIO NR Series, HP TouchPad running CM9, Jailbroken iPod Touch 4G
Colonel O'Neill
Heh. Sometimes it throws a curveball and goes "driver is not for your version of Windows", but I haven't seen it recently.
I'm going to try the 11.4 Catalyst desktop drivers to see if they're faster. Installing the 11.4 Mobility driver consistently produces system freezing/BSoDs for me, but the driver always seems to install properly; Device Manager shows 8.841.
I much prefer the manual switching over Optimus; don't want it to accidentally trigger or not trigger.
hunterman223
Are the BSODs a repetitive thin or is it just when installing? Let me know how the desktop drivers go and if they're any better.
Optimus does seem to be very finicky at the moment, what with all the posts saying it is very difficult to manually switch back and forth and not fully supported by games and 3d apps.
Hunter Thompson
Colonel O'Neill
The desktop driver doesn't seem to be any faster. No BSoDs during usage or gaming so far, so it looks restricted to the installation. The desktop version (doesn't seem to need any modding) installs fine; the mobility one seems to cause BSoDs. My system has been acting up for the past few months, but have been too lazy to reinstall.
hunterman223
Thanks. Just to clarify, the mobility driver does cause BSODs besides during installation? If so I'll hold off on installing it for now.
Hunter Thompson
Colonel O'Neill
I meant it doesn't BSoD during usage. Only happens during installation. The desktop one seems to work all around anyway.
hunterman223
Which one would you recommend that I use?
Hunter Thompson
Colonel O'Neill
I'd go with the desktop one. Any mobility battery savings are pointless with the Intel card. I also realized I was running the desktop drivers on my X100e too, so it seems fine.
hunterman223
Thanks, I'll update when I have the machine.
Hunter Thompson
Colonel O'Neill
Blah. Might want to hold off on installing the 11.4 drivers. They seem to cause Dead Space 2 to glitch on shadows.
hunterman223
Hmm. Maybe I should wait for the stable release. As you can see I from my games list I won't really be left in gaming withdrawal or anything.
Thanks for all your help.
Hunter Thompson
Colonel O'Neill
Heh. It is the 11.4 stable release. 11.4 RC2 has the issue too, but 11.3 doesn't.
No other games seem to be affected. Yet to try Crysis 1, but Crysis 2 worked fine with 11.4 RC2.
I have a new 64-bit install sitting on another partition; I'll see if it still happens there.
hunterman223
Interesting. I wonder if it would effect me then? My guess is no, but I guess we'll have to wait and see.
Hunter Thompson
Colonel O'Neill
Highly doubt it'd be an issue. Out of all the stuff I have, I only see the issue on Dead Space 2. If it does end up being a problem, rolling back to 11.3 works.
hunterman223
Okay, sounds good. Hurry up, USPS!
Hunter Thompson
Colonel O'Neill
Just a quick update: 11.5 preview doesn't have issues with Dead Space 2.
hunterman223
That's great. Any performance boost from 11.4?
Hunter Thompson
Colonel O'Neill
Not significantly. Going from 11.2 to 11.4 was a massive performance increase.
hunterman223
Thanks for the update. The T400 should hopefully get here early next week so I'll try it out then.
Hunter Thompson
hunterman223
Forgot to ask: Does 11.5 cause a BSOD during installation?
Hunter Thompson
Colonel O'Neill
That it doesn't.
hunterman223
Cool, I'll download that one then. Sometimes it's better to be on the cutting edge.Colonel O'Neill wrote:That it doesn't.
Hunter Thompson
hunterman223
Update: Got the T400 yesterday, and everything is up and running with 11.5. Everything's great, my WinSAT scores before overclocking were 4.8 desktop / 5.7 gaming.
I am now overclocked with the same setup and clocks as you, 850/899. I haven't done much for stability testing, just playing Burnout Paradise and running WinSAT. My new scores are 5.0/5.9, and I'll have some detailed FPS tests done later. Using fraps I notices 40-50fps on low before overclocking, with medium being barely playable at 20-30fps. After overclocking I am getting 50-60fps on low and 40-50fps on medium depending on the scene, so definitely a major improvement. I am also using GPUtool with two different profiles set up like you mentioned, and it works great.
I'm really impressed! I wasn't expecting that much of a boost, or for it to be so easy.
I'll update later with some more detailed benchmarks.
Hunter Thompson
hunterman223
Update: Interesting. Not as big of a difference as I previously mentioned, but somehow enough to go from barely playable to fully playable on medium, and smooth as butter on low. Here are the details:
Burnout Paradise Stock - Medium Quality
Frames Time (ms) Min Max Avg
1771 60000 22 36 29.517
Burnout Paradise Stock - Low Quality
2851 60000 40 55 47.517
Burnout Paradise OC'd - Medium Quality
2121 60000 21 45 35.35
Burnout Paradise OC'd - Low Quality
3114 60000 44 61 51.9
As you can see, interesting results. I suppose to be taken with a pinch of salt due to different scenes, etc. It is definitely a great improvement either way, benchmarks or not. I'll have to give some other games a try.
Hunter Thompson
Colonel O'Neill
Nice! Free performance!
May want to watch out when the temperatures start rising; it glitches more often if I run something intensive and forget to crank the fan up to 4500RPM.
hunterman223
Yeah, definitely impressive!Colonel O'Neill wrote:Nice! Free performance!![]()
I've been watching the temps with Everest, and haven't seen anything too high yet. I'll update if I find out anything else.
OT: Just something I noticed, WD Scorpio Black is definitely noisy, and hot. Another reason I am shooting for an SSD, the spinning and whirring is all you hear due to the whisper silent fan... Definitely happy with my new T400, and I see quite a bit of potential with a few upgrades.
Hunter Thompson
Colonel O'Neill
The 500GB Scorpio Black doesn't make any noise at all for me except the slight whooshing under normal usage, nor does it go above room temperature on the palmrest. O.o
Which defragger do you use?
The 320GB Scorpio Black I had for a while got quite warm, but the 500GB one doesn't.
hunterman223
Strange. Mine is also the 500GB, WD5000BEKT. It can definitely be heard spinning from a few feet away. It's not crazy loud, but it's louder than I expected. It does get quite warm as well if I frequently open and close things or move around files. I have been using Auslogics Disk Defrag for quite a while and I run it regularly.
I'll put some temps up later. How warm does yours run?
Hunter Thompson
Colonel O'Neill
Yep, I have the WD5000BEKT as well. The spinning noise is indeed evident in a silent room. Under normal usage, it ranges from 36 to 40C according to HWMonitor. During defrags, it usually goes between 39 and 41C. The palmrest stays more or less ambient temperature. The 320GB I used to have warmed it up significantly; HWMonitor would report up to 48C.
IIRC, Auslogics doesn't move old files to the inside of the drive but rather only moves system files to the outer rim. Not the best algorithm, though. I've been using UltimateDefrag for the past while and it keeps file accesses almost exclusively within the outer tracks. Doing accesses on the inner portion, one can hear light seek noise and the temperatures go up. It is paid, but I suppose some scripting with MyDefrag would also get the job done.
Best HDMI Graphics card to stream video to TV from M58P-MJV2740 ?
by E350 » Sun Jan 22, 2017 11:51 pm » in IBM or Lenovo Desktops/Workstations/ThinkStations only - 9 Replies
- 1124 Views
Last post by E350
Fri Feb 17, 2017 1:12 pm
WTB W701 Parts Express Card or CF/Express Card Board
by MisterB » Mon Jun 19, 2017 4:43 pm » in Marketplace - Forum Members only - 1 Replies
- 125 Views
Last post by MisterB
Mon Jun 26, 2017 9:57 pm
ThinkPad X220 gaming benchmarks and graphics benchmarks
by PaulBrause » Sun Jan 15, 2017 2:34 pm » in ThinkPad X200/201/220 and X300/301 Series - 4 Replies
- 1166 Views
Last post by Digitalhorizons
Sun Jan 29, 2017 5:42 am
Nvidia Graphics and video editing
by Whitieiii » Fri Jan 27, 2017 12:59 am » in GENERAL ThinkPad News/Comments & Questions - 22 Replies
- 1109 Views
Last post by farmall77
Thu Feb 09, 2017 1:25 pm
