Graphics Card Comparison
hunterman223
Running an UltimateDefrag right now. What mode do you have yours set to? I left it at the default Consolidate mode, but there are a few others to choose from. I lime the program so far. At the moment I am running nice and cool at 36C, but by touch I can tell it has been hotter than that. I'll let t run for a while and let you know.
Sent from my iPod touch using Tapatalk
Hunter Thompson
ThinkPad T400: T9400, 8GB, LG WXGA+, Samsung 830 128GB + WD Scorpio Black 500GB, Intel 5300agn, Win7 Pro x64
Others: IBM ThinkPad R40, Sony VAIO NR Series, HP TouchPad running CM9, Jailbroken iPod Touch 4G
Colonel O'Neill
Re: Graphics Card Comparison
I have it set to Volatility, with High Performance, Archive, and Move Directories to MFT checked. Under settings, I have the following settings (simplified for simplicity):
High Performance:
Custom: Checked Program Files; ProgramData\Microsoft,Lenovo,Start Menu,Kaspersky,ATI; Windows\System32,SysWOW64,winsxs
Filetypes: *.exe, *.dll, *.ocx, *.sys
Archive:
Automatic: Last 14 days not used
Custom: Massive downloads folder
Filetypes: *.zip, *.rar, *.iso, *.7z, etc.
I'm still playing with it to get an optimal setup; there's lots of fluff the above includes in High Performance that I'm pretty sure doesn't need to be. Your mileage may vary.
It's a highly configurable defragger, and you should end up with about 80% of the data going to the middle of the drive. As it's a new install with new filedates, you might want to let it use 80% least used for Archive. Also should enable all four options when it asked at first run (subsequently accessible in Tools under the More tab).
Highly recommend reading it's included manual; quite informative about the whole concept.
Also, Kaspersky's Self-Defense interferes with it; disable it for defrags. Not aware of any other self-defense systems that interfere with UltimateDefrag though.
High Performance:
Archive:
hunterman223
Thanks, running another defrag now with that config, looking good. HDD at 41C making for a nice toasty palmrest. It would be nice during winter...
BTW, what software do you use to get the fan to 4500rpm? Using TPfancontrol on it's max level of 7 I am only getting ~3500rpm.
Hunter Thompson
Colonel O'Neill
41C sounds about right during a defrag.
Fan level 64 brings it to 450PRM. It's technically an unsupported speed, but htere for emergency purposes. Probably wears out the fan more. Significantly louder than 3500RPM.
EDIT: Whoops. Looks like including the filetypes in High Performance added a whole lot of useless EXE and DLL files. Never really noticed. (d'oh)
hunterman223
Yeah, it seems to stay at a max of 41C with anything intensive, and gradually goes back down. For now 3500rpm seems to do it, but if I get into anything more intense I'll put it at level 64.Colonel O'Neill wrote:41C sounds about right during a defrag.
Hmm. Live and learn
Hunter Thompson
Colonel O'Neill
Yeah, boot time moves the MFT, pagefile, hiberfil, and NTFS related metadata objects. I tend to leave it right inside the ring of files on the outside. It's bizarrely placed in the Settings dialog, and you have to check the "Run on next boot checkbox".
I think removing all of the filetype selectors in High Performance would be a good idea; it was picking up on all of the DLLs from Visual Studio 2010, among other things.
hunterman223
Okay, thanks. Updating the config now. I am really liking UltimateDefrag, it seems very configurable and a great tool once you get the hang of it.
Hunter Thompson
hunterman223
More news! Currently I am in the process of undervolting my T9400. I am seeing excellent results; at the moment I am running a stress test for 0.9625v, down from the default of 1.1625v, and my Max Temp. readings have gone down by 18C! That's right, 18 degrees Celsius!
That seems to be the "ceiling", as it has stayed 18 degrees lower for the past few lower voltage & stress test cycles. I also have done the half multiplier hack to make RMClock use 9.5x for my CPU. Really loving my new ThinkPad!
One quick question: I know that RMClock is capable of underclocking, or locking the multiplier to save battery life. Will this interfere with Power Manager? (since it basically does the same thing) How will I need to set this up so the two play nice?
Update: Black screen with the voltage I mentioned above, BSOD error 1e according to event viewer. Doing a 3 hour stress test on 1.0125v (2 steps above) and I'll let you know how it goes.
Hunter Thompson
Colonel O'Neill
Windows sometimes likes to set mine to 6x @ 1.000V for a split second. If I set it to 100% min/max CPU in Power Options (not Power Manager) then it seems to stop trying.
As for the 9.5x hack... My P8700 shows a 10.0x called IDA that seems to do the 2.53GHz for which the CPU is rated. Not sure if it's the same with the T CPUs.
I recommend using IntelBurnTest at 2 threads instead of Prime95; it seems to push it harder.
EDIT: Way OT, but in case you haven't stumbled across it yet, TwoFingerScroll enables some multitouch on the T400 touchpad with regular UltraNav drivers.
hunterman223
I have the IDA option too, but I read that it is best to leave it off as it is finicky. I guess it disables one core for a short time or something, according to the undervolting guide over at NBR. I edited the PStatesData key in the registry and it's working great at the moment.
I ran orthos overnight and it passed, but I'll let IntelBurnTest run for a few hours, it can't hurt to be extra stable.
I'll have a look at the two finger scrolling thing. I would be nice to have some mutitouch functionality. OT isn't much of a concern, since we have now compared graphics cards, overclocked them, talked about UltimateDefrag, undervolted, and now multitouch!
Hunter Thompson
Colonel O'Neill
IDA hasn't seemed to cause any issues for me yet.
As long as we're off-topic, here's a random tidbit:
Disable the "Intel(R) Management Engine Interface" in Device Manager under System devices. This prevents HECI.sys from loading, and reduces DPC latencies in case you have audio dropouts. I'd disable it anyway to keep it from doing unnecessary things. Not an issue if you didn't install the Intel AMT driver in the first place, but I don't like seeing yellow exclamation marks in my Device Manager
hunterman223
Thanks, disabled it. I haven't noticed any issued, but there is no point in leaving it enabled anyways.
Something interesting: I forgot to switch back to the default GPUTool profile once I exited a game, and no freezing, black screens, or anything out of the norm. HWMonitor reads the voltage at 0.9v. I guess I am just lucky
More news on the undervolting, I have finished, and I have "finalized" it. I'm running 18C cooler at the cost of nothing. On a side note, playing Burnout Paradise for 30-40 minuted warmed up the CPU more than a few hours of Orthos. Either way, the difference between before and after undervolting is still ~18 degrees Celsius.
I'm gonna let it cool down for a while and then unplug and try out the battery. I already got great battery life, so I don't expect a ton of improvement in that department.
Hunter Thompson
Colonel O'Neill
It can run at 0.9V for a while with higher clocks. It's just occasionally crashy, especially at higher temperatures.
You can always try OCCT for maximum heat
Ultimately, depending on how well your GPU is, you might be able to hit even higher clocks.
hunterman223
Ahh, makes sense. I'm glad it's not an instantaneous thing though. I might give OCCT a try tomorrow, but I'm fairly certain all is stable anyways. I think I'll leave the clocks alone for the time being, I'm quite pleased with them and I don't think I could get them enough higher to justify anyways.
OT: Does the right side of your palmrest by the HDD cover and ThinkPad logo creak? It's almost like the plastic of the palmrest and the HDD cover are rubbing together and creaking. It only creaks if I press it just right, but once I find it it's really annoying.
Hunter Thompson
Colonel O'Neill
It always had. That said, it's been dropped on that corner plenty of times (probably what killed the FPR
). Enough to seriously contort the HDD cover itself, but with some heat, it bent right back into shape (more or less) and it doesn't creak anymore but the cover and palmrest don't align perfectly. Maybe lining the edge of the HDD cover with a thing piece of tape would work?
Just thought I'd chime in on this bit of OT: My T400 creaks in exactly the way you guys describe on the palm rest at the lower right corner. The palm rest seems to not be anchored to anything there; I've meant to remove the drive and see if the problem isn't possibly related to a screw not being tight enough or something similar. Over the 16 months or so that I've had this machine, I can't decide if various creaky parts, oddly shaped gaps, or not-quite-perfect fits on the shell are shoddy workmanship or were purposefully designed to isolate stress or shocks to a small region rather than transporting it across the entire chassis.
Back on topic: Colonel, how do you generally find the gaming experience on your T400? You've listed a few games that tax my modest desktop rig a good amount (2.4Ghz dual-core Opteron, 512MB Radeon X1900 runs the Crysis demo at about ~20-25 FPS with stuff like AA and filtering disabled and shadows turnd to the lowest setting). Gaming-wise, I've only really tried Portal on my T400; while that was before updating to some of the newer Catalyist drivers, it seemed like I had to turn down or off a good amount of the settings just to get something more or less playable. I currently have a 5.7 on the WEI Gaming Graphics section, so I would expect some decent performance, but I haven't really thought about gaming too much on this machine beyond the occasional Minecraft session. Are there any particular tricks you've had to resort to (other than overclocking the GPU)?
Colonel O'Neill
My T400 is moderately game-able. Wouldn't mind an HD3650, though
That said, I'm used to less than smooth FPS gameplay; used to play CS 1.0 on an ancient 233MHz Compaq laptop with a 256MB NeoMagic video card running Windows 2000.
I'm also running 32-bit Windows, so that might help with certain games. Overclocking and the newest Catalyst brought the most improvements overall, and Game Booster keeps framerates more consistent by a bit. Some games are more CPU dependent as well, like AudioSurf and CS:Source, so undervolting there lets me stay at top speeds all the time. Ramping fan speed up to 4500RPM also keeps the GPU from throttling while overclocked.
hunterman223
I've had a pretty major breakthrough! My 3470 is now at a 60% overclock. To put that in perspective, here are some 3DMark06 screenshots.
This is the score at default clocks, 680/800.
This is the score at the settings I have been using for awhile now, 850/899.
And this is the score with my current clocks, 880/1120.
I guess you were right when you said I may be able to go higher. My WinSAT/WEI went from 4.8 (non-OC) --> 5.0 --> 5.5. Not bad at all! But more importantly I am actually noticing it in games, for example when playing GTA San Andreas I used to lag quite badly when I used the turbo cheat. Everything else was smooth. Now it is perfectly smooth with no lag at all.
I didn't have much of a method, I just pressed "Find Max" in GPUTool and let it run for 5-10 minutes. It found the maximum clock speed without errors, when errors were encountered it dropped the clocks incrementally. I than ran WEI several times, the first two times I ran it I had some artifacts & black screens, so I dropped the clocks 10MHz until everything ran smoothly. That's it really. My temperature readings haven't gone up anything noticable. I am seeing a max GPU temp of 65C after running 3DMark06 3 times for the above screenshots, which isn't bad at all. It is slightly lower than that with the games I play. I said before that I never noticed the freezing when going from 1.20v to 0.9v; now I do. I just have to remember to switch profiles as soon as I am finished and everything's fine.
Tomorrow my 8GB of memory should show up, at the moment I have 6GB but it is an unmatched pair so I have been forced to stay on ATI graphics. When using the Intel I get all kinds of graphical glitches and artifacts, apparently due to the shared memory and the Intel chipset not handling the unmatched pair correctly. Live and learn, but it's strange that so few people mentioned it. I assumed it would be fine due to the Intel Flex Memory, but I guess not. I will rerun the benchmarks tomorrow and see if the score took a hit due to being in some sort of virtual dual-channel mode.
I think I have a lucky T400.
Hunter Thompson
hunterman223
Got the 8GB of RAM today The 3DMark06 score didn't change much, the scores are as follows:
3DMarks:.....3299
SM2.0:........1122
HDR/SM3.0:..1335
CPU:............2285
Now my virtual machines have some breathing room, and my battery life is back in shape as I can now use Intel graphics again.
3DMarks:.....3299
SM2.0:........1122
HDR/SM3.0:..1335
Hunter Thompson
Colonel O'Neill
My temperatures race up to 72C on the 850/899 overclock while gaming... Stuff actually starts throttling unless I kick the fan into level 64.
hunterman223
Huh. I never have to ramp mine up to level 64 while gaming, only level 7. My temps stay somewhere around 65C while gaming with the new clocks. I must be really lucky or something.Colonel O'Neill wrote:![]()
MOAR! XD
Hunter Thompson
Best HDMI Graphics card to stream video to TV from M58P-MJV2740 ?
by E350 » Sun Jan 22, 2017 11:51 pm » in IBM or Lenovo Desktops/Workstations/ThinkStations only - 9 Replies
- 1124 Views
Last post by E350
Fri Feb 17, 2017 1:12 pm
WTB W701 Parts Express Card or CF/Express Card Board
by MisterB » Mon Jun 19, 2017 4:43 pm » in Marketplace - Forum Members only - 1 Replies
- 125 Views
Last post by MisterB
Mon Jun 26, 2017 9:57 pm
ThinkPad X220 gaming benchmarks and graphics benchmarks
by PaulBrause » Sun Jan 15, 2017 2:34 pm » in ThinkPad X200/201/220 and X300/301 Series - 4 Replies
- 1166 Views
Last post by Digitalhorizons
Sun Jan 29, 2017 5:42 am
Nvidia Graphics and video editing
by Whitieiii » Fri Jan 27, 2017 12:59 am » in GENERAL ThinkPad News/Comments & Questions - 22 Replies
- 1109 Views
Last post by farmall77
Thu Feb 09, 2017 1:25 pm
