T42 Fan replacement
Re: T42 Fan replacement
#61 Post by RealBlackStuff » Fri Mar 20, 2015 10:18 am
Click on the HMM link at the top of this page, to download the Manual for the T42.
(scroll down to ThinkPad T40, T40p, T41, T41p, T42, T42p).
All info with part numbers, pictures etc. is in there.
pafka99
#62 Post by pafka99 » Fri Mar 20, 2015 11:03 am
Hi RealBlackStuff. Thank you for your answer.
There's a problem - TYPE 2374-Q1x doesn't exist in the Manual :roll: that's why I am confused about FRU.
pict of the SN and Type tag https://www.dropbox.com/s/7c6fbo00fhika ... 0.jpg?dl=0
My question is - which fan should I buy according this TYPE and SN?
#63 Post by RealBlackStuff » Fri Mar 20, 2015 11:56 am
26R7860 if yours has a 14.1" screen
13R2919 if yours has a 15.0" screen
Why don't you check on the P/N or FRU on the fan that's in there now?
KRAZY KEV
#64 Post by KRAZY KEV » Sun Apr 12, 2015 8:53 am
Not sure if its the same part but i replaced the fan on my T43 a few months ago. it was only around £6 brand new (UK price). i had it off ebay. little did i know it was identical to the original fan.
it takes around 2 hours to fit it.
what i did notice when i removed the original noisy fan is that the fan actually lifts off its spindle. this would allow you to lubricate the bearing and refit it. one drop of 3 in 1 oil should do the trick
rohaiza4
#65 Post by rohaiza4 » Mon Jul 13, 2015 7:05 am
Hye guy here i want to show you guide to replace the fan only on IBM t42, t41 or other similar in T series.
check it out, it solved the Fan error issues. only by replacing new / used working fan..
http://atozcs.net/this-how-to-replace-i ... fan-error/
