Memory is my problem. I'm getting intermittent BSODs with messages pertaining to memory faults so I've snipped the wire for now. I'm ordering a 2gb stick soon and will try again then.
Any recommendation on what memory to get for OC'ing?
--Dan
Here's a summary of the benchmarks:
EVEREST Ultimate Edition
Version EVEREST v5.50.2100
Benchmark Module 2.5.292.0
Memory Read
CPU CPU Clock Motherboard Chipset Memory CL-RCD-RP-RAS Read Speed
Pentium M LV 758 1500 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-400 4-3-3-9 2548 MB/s
Pentium M LV 758 2000 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-533 4-4-4-12 3390 MB/s
Memory Write
CPU CPU Clock Motherboard Chipset Memory CL-RCD-RP-RAS Write Speed
Pentium M LV 758 1500 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-400 4-3-3-9 2125 MB/s
Pentium M LV 758 2000 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-533 4-4-4-12 2832 MB/s
Memory Copy
CPU CPU Clock Motherboard Chipset Memory CL-RCD-RP-RAS Copy Speed
Pentium M LV 758 1500 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-400 4-3-3-9 2011 MB/s
Pentium M LV 758 2000 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-533 4-4-4-12 2530 MB/s
Memory Latency
CPU CPU Clock Motherboard Chipset Memory CL-RCD-RP-RAS Latency
Pentium M LV 758 1500 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-400 4-3-3-9 123.6 ns
Pentium M LV 758 2000 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-533 4-4-4-12 101.3 ns
CPU Queen
CPU CPU Clock Motherboard Chipset Memory CL-RCD-RP-RAS Score
Pentium M LV 758 1500 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-400 4-3-3-9 2911
Pentium M LV 758 2000 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-533 4-4-4-12 3886
CPU PhotoWorxx
Pentium M LV 758 1500 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-400 4-3-3-9 2624
Pentium M LV 758 2000 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-533 4-4-4-12 3307
CPU ZLib
Pentium M LV 758 1500 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-400 4-3-3-9 9130 KB/s
Pentium M LV 758 2000 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-533 4-4-4-12 12194 KB/s
CPU AES
Pentium M LV 758 1500 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-400 4-3-3-9 2647
Pentium M LV 758 2000 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-533 4-4-4-12 3539
FPU Julia
Pentium M LV 758 1500 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-400 4-3-3-9 599
Pentium M LV 758 2000 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-533 4-4-4-12 804
FPU Mandel
Pentium M LV 758 1500 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-400 4-3-3-9 280
Pentium M LV 758 2000 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-533 4-4-4-12 373
FPU SinJulia
Pentium M LV 758 1500 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-400 4-3-3-9 337
Pentium M LV 758 2000 MHz [ TRIAL VERSION ] i915GM Int. Dual DDR2-533 4-4-4-12 450
