I'm curious. As I read the posts I notice the litany of model numbers post-post, so to speak.
Do you guys use a multitude of computers for various functions, ie office, travel, home, coffee shop, etc, or ...what.???
I'm looking for one unit to do it all. Maybe I shouldn't. I have a unit the office gave me, but is fairlly locked down Maybe i should think small portable for travel-coffee shop and a larger unit for home office use. Is this what most of you do??? If so do you have trouble knowing where all your files are at. As I said, just curious.
Thx.
Frank
X1 vs T420s
Re: X1 vs T420s
Most of us are computer enthusiasts, and as such we often have quite a few computers.
But usually it is not necessary.
With that said, I do think 2 computers - a desktop and a laptop are the sweet spot.
Desktop - for performance, storage and long-term reliability (easier to fix/replace parts, easier to upgrade, usually cheaper too).
Laptop - for traveling, for taking your work with you, for going between home and office (unless the workplace issues you a company PC, then it may not be necessary to take it with you).
Which laptop - depends on your work style. If you travel a lot and do simple things while on the road, a small light machine is probably better; if you need to do serious computations or regularly work with applications requiring large screen space - a bigger machine with a higher resolution screen may be better for you.
For that purpose, pianowizard's poll about resolution vs portability can be quite informative:
http://forum.thinkpads.com/viewtopic.php?f=58&t=103968
Now, in some cases it is possible to get by with one machine. For example if you never need to travel with your work, and never need a computer on the road (because you have a tablet/smartphone for those small things) - then you can get by with just a desktop or a desktop replacement laptop.
If you want to avoid the desktop, it's possible to get powerful desktop replacement machines, which can compete performance-wise and storage-wise, but they will be very big, very heavy, very expensive. Not good for portability, unless you like chugging 5 kilos with you everywhere you go (if you drive everywhere it matters less).
Re: X1 vs T420s
I've got five PCs - three desktops and two laptops. There's my main desktop, then I've got two media servers. My X220i is my main laptop. The R60e mostly sits in the guest room, though I do bust it out when I write my reviews for the vertical resolution.
E7440
Re: X1 vs T420s
I'll have to save these to show my wife<g>.
I'd like to do the duel computers. I can see it working fine.
I have a notebook that I use as my desktop, but it's a bit heavy to lug around.
To me, size and weight is most important.
I have an HP from the office that is kinda locked down to just office stuff.
It's real heavy at 5.25 #.
The X1 coming out looks real nice.
Maybe one of those all in ones for my desk.
Saw a Sony L at the mall.... Looked pretty nice. Don't know if there is a good one from Lenovo.
Thx.
Frank
Thx.
Frank
CANNOT FORMAT 2tb usb 2.5" seagate sata hard drive ON T420S WITH WINDOWS 10
by MontanaKitty » Sat Jan 21, 2017 12:28 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 3 Replies
- 845 Views
Mon Jan 23, 2017 9:40 am
T420s/430s FHD/2k upgrade
by tomatohat » Sun Feb 05, 2017 1:31 pm » in ThinkPad T430/T530 and later Series - 18 Replies
- 1960 Views
Last post by llemon
Wed May 24, 2017 6:05 pm
Upgrade T420s wifi
by turomini » Wed Feb 08, 2017 1:52 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 5 Replies
- 1131 Views
Last post by turomini
Wed Feb 15, 2017 9:00 pm
T420s i7 with backlight but no image - bad cable or LCD?
by ji2o0k » Wed Feb 15, 2017 11:56 am » in ThinkPad T400/410/420 and T500/510/520 Series - 3 Replies
- 874 Views
Last post by ji2o0k
Tue Feb 21, 2017 10:15 am
