Does the Lenovo 12W 51J0476 sleeve fit the X61t?
Hi all
I searched for a bit but couldn't find the answer. Does anyone know if the neoprene sleeve that Lenovo sells (51J0476) fits the X61 tablet with the extended 8-cell battery? I'm asking because it's supposed to also fit the X200t but apparently w/ extended battery but I heard some users claiming otherwise, but couldn't find any info on the X61t.
I have the Case Logic NCLE-2 sleeve that fits my T60p w/ extended battery like a charm, but I can't seem to find the equivalent, a suitable, simple, no-frills neoprene sleeve that fits my beloved tablet.
TIA!
TIA!
T60p 15" UXGA
X61t 1.8Ghz SXGA+ AIFF
Re: Does the Lenovo 12W 51J0476 sleeve fit the X61t?
Rather than a sleeve, I found (I think) the perfect bag for my X60s with extended battery: Sportfolio II Case for Notebooks up to 12"
It originated in the Mac world but suits the X60/X61 to a tee: http://cgi.ebay.com/Sportfolio-II-Case- ... 0515189105
Hi! For that price, it's a bargain!
But I am looking for a sleeve, rather than a bag. Thanks anyway.
T60p 15" UXGA
This sleeve may/may not suit your needs (?) - Sleeve Bag Soft Laptop Case IBM Thinkpad X61T X60S X61S
Hi!
It doesn't - had to find out the hard way in spite of the seller's claims! Happily, I resold it on a local listing straight after.
T60p 15" UXGA
Ah, OK - you've already been down that road
- What about current sleeves from Case Logic? - If you do manage to find a sleeve, please let the forum know as there may members who are in the same situ etc.
Yeah - it was really annoying as I specifically asked the seller if it fitted the tablet w/ 8 cell to which he responded it did.
I've spotted a couple of case logic, but I can't really tell... one thing is for sure they'll be too wide, and possibly not high enough... hence my posting on this board.
It's a shame, really, my case logic 15" fits the T60p perfectly...
T60p 15" UXGA
Would that one fit an x61 with a standard battery?kamaleon wrote:Hi!
X61 7674
Intel 320 80GB
4GB RAM
Middleton Bios
Win 7 x64 Ultimate
RMClock
TPFanControl
X6 Ultrabase
Ultrabase HD Caddy
Ultrabase DVDRAM
Intel 320 80GB
4GB RAM
Middleton Bios
Win 7 x64 Ultimate
RMClock
TPFanControl
X6 Ultrabase
Ultrabase HD Caddy
Ultrabase DVDRAM
Yes, it does, no problem.inogen wrote:Would that one fit an x61 with a standard battery?
T60p 15" UXGA
Which Ultrabay Slim batteries fit which ThinkPads?
by bakery2k » Fri Apr 14, 2017 8:45 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 3 Replies
- 733 Views
Fri Apr 14, 2017 9:38 pm
What exactly was the R series trying fit?
by Thinkpad4by3 » Fri May 26, 2017 10:53 am » in ThinkPad R, A, G and Z Series - 2 Replies
- 358 Views
Last post by TPFanatic
Fri May 26, 2017 12:40 pm
Replace beloved X61T... Suggestions?
by bobcardone » Sun Jan 29, 2017 10:26 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 1 Replies
- 1356 Views
Sun Jan 29, 2017 1:52 pm
Closed: Vista Business recovery discs for X61t
by fultontech » Sat Mar 18, 2017 9:36 pm » in Marketplace - Forum Members only - 0 Replies
- 203 Views
Last post by fultontech
