Model M Keyboard
Talk about "WhatEVER !"..
steveg1988
Model M Keyboard
#1 Post by steveg1988 » Tue Jun 07, 2011 4:50 am
anyone here still use them? the last one i bought was improperly cleaned by its prior owner causing major issues with usability
Nigellus
Re: Model M Keyboard
#2 Post by Nigellus » Tue Jun 07, 2011 11:31 am
Haven't used one since the '90s. Love them, though, and I'm thinking of getting another one.
T420 i5-2520M 2.50GHz 4 GB RAM 64-bit OS WIN7pro SP1
T60 1951-46U Intel Core Duo 1.83GHz 1 GB RAM 60 GB XPpro
TP 600E 2645 PII 366MHZ 160MB RAM 37.2GB WIN98SE
Computers do exactly what you tell them at amazing speeds; this can be bad if what you told them wasn't what you had in mind.
lead_org
#3 Post by lead_org » Tue Jun 07, 2011 12:09 pm
using a Model M compatible built by Unicomp at work, not as good as the original steel plate IBM version Model M, but it is still the best mechanical keyboard out there.
Unknown_K
#4 Post by Unknown_K » Tue Jun 07, 2011 2:55 pm
I have over half a dozen, using one currently in my room (main machines) connected to a KVM. Since I collect PS/2 MCA systems I tend to snag Model M keyboards for them.
If you like Model M clicky keyboards snag an old Northgate, they are also very good.
Collection: 310ED, 350C, 360C, 365C, 365XD, 380D, 380XD, 380Z, 390E, 390X, 560X, 600, 600E, 701C, 750CS, 755C, 755CD, 760C, 760CD, 760ED, 760EL, 760XD, 760XL, 765L, 765D, 770, 770E, 770Z, T21, T22, T23, T30, A20P, A21P, A22M, A30, A31, A31P, T40, T42, T43P, T60, T61, R32, R40, R52
virge
#5 Post by virge » Wed Jun 08, 2011 5:08 am
I have one Model M and about 6-7 of the M-13 models. I started out with one M-13 and liked it so much I bought a "few" extras. I figure they probably weren't going to get any cheaper with time.
From what I understand, the M keyboards were durable in most ways, but are susceptible to moisture. The traces in these boards are fairly large though, so if you open it up you may be able to fix it. If you have keys that aren't working, it might be worth a shot.
ThinkRob
#6 Post by ThinkRob » Wed Jun 08, 2011 12:33 pm
I've got one of the early Lexmark Model Ms at my work desk. I love it.
I've also got an M13 at home (which I don't use, as I don't really like it too much).
I'm considering getting one of the early-model IBM Model Ms (with the stabilizers), but I'm having trouble finding one in very good to mint condition. I'm willing to pay, but there just aren't that many out there...
I have two other keyboard models that I prefer more than the Model M: the Apple Keyboard and the Apple Extended Keyboard II. The former is a great compact keyboard with excellent Orange ALPS switches and has the Control key in the correct position, and the latter has dampened ALPS switches which (to my knowledge) were never used in any other keyboard. I love the feel of the AEKII more than any other keyboard, but the AK is a close second. I'm refurbishing a couple AKs right now, and will be converting at least one to USB...
Current laptop: X1 Carbon 3
Current workstation: none
ParatoOptimal
#7 Post by ParatoOptimal » Thu Jun 09, 2011 1:38 am
Become an R or X addict.
770E (relic not in use
3000 N100 T2080 1.73GHz
R61 773-1GU
T41 2373 7FU Pentium-M 1.6GHz Banias
X31 2672 XXM Pentium-M 1.3GHz
X60s 1702-68U L2400 1.66GHz Core Duo
Compaq Portable (suitcase size, gone)
Mac Portable (first laptop in world, Stored
Mac Laptop (Stored
Toshiba Tecra (Stored
bgalakazam
#8 Post by bgalakazam » Thu Jun 09, 2011 2:50 am
I want to get one. Preferably under $20 LOL. It's ghetto.
15" Macbook Pro, T400 for car diagnostics
previous: T60p -> X60 -> T61 QXGA -> X220 -> W510
Return to “Off-Topic Stuff”
