after having had two more damaged x60-boards (one bad graphics and one all black, seller from the UK), I did receive a technically (PC-Doc) seemingly fully functional board from the US. I did update the bios (Zenders) as I want to use a more recent WLAN-card.
Now I do receive a 0191-Error at boot , as if the board did wait for / request a confirmation of its update via LAN. Would it suffice to take of both batteries (normal one and the bios battery) to get rid of that interference? As I did not receive that error before, it should not be anything more serious...
Any advice how to overcome this state would be appreciated...
Thanks in advance...
P.S.: I happen to find ebay becoming a less reliable source of used parts...
Solved/ outdated)-0191 error: X60 board from a former company network (?)
friedrich-eugen
- thinkpads.com customer
Last edited by friedrich-eugen on Thu Aug 06, 2015 11:07 am, edited 1 time in total.
__friedrich-eugen__
started with IBM-XT (80186) and AST-Ascentias NB (910N) in the 90ties, relying on Thinkpads (770X, A31Ps) until 2012,
now using an upgraded T60-61P "Frankenpad" (15"UXGA-LED Penryn 8GB 500GB/7200), and an X201/X230T (i7 8/16GB/500GB) Windows10
Re: 0191 error: X60 board from a former company network (?)
Removing CMOS battery might help.
If not, try reflashing the BIOS with the Lenovo version, if need be first with an older version, than the latest.
friedrich-eugen
Thanks Realblackstuff,
the bios-message was misleading, the fix easy:
I had mistakenly disabled some bios-features (network-related) before updating the bios.
I just changed to "default" and redid the bios update (forced as zender showed by flash2/u). After a full shutdown and reboot the errorcode did not show up again.
I redid the disabling, all seems now ok.
Thanks for Your swift reply
__friedrich-eugen__
- 16 Replies
- 953 Views
Tue May 09, 2017 12:11 pm
(Company + Individuals): Strategies to Mitigate Cyber Security Incidents
by RealBlackStuff » Tue Feb 07, 2017 9:40 am » in ** HOW TOs & FAQs ** - 1 Replies
- 750 Views
Last post by Digitalhorizons
Tue Feb 07, 2017 1:39 pm
SOLVED IDTech IAQX10 QXGA panel
by x3o2 » Sun Jan 15, 2017 8:20 am » in Marketplace - Forum Members only - 8 Replies
- 1049 Views
Last post by x3o2
Mon Apr 03, 2017 12:09 pm
SOLVED! Recovery media for T410 2518-4LU W7 Pro 64
by rakirkp » Sun Jan 22, 2017 11:22 am » in Marketplace - Forum Members only - 1 Replies
- 262 Views
Last post by theterminator93
Sun Jan 22, 2017 1:28 pm
