Which Thinkpad to buy?
ZaZ
moderator
moderator
Re: Which Thinkpad to buy?
#61 Post by ZaZ » Sun Nov 20, 2011 3:10 am
pianowizard wrote:Do you view everything in full-screen mode?
My desktop has two LCDs. Does that count? While your point is completely valid, it's been my experience for most users, vertical resolution is more important.
E7440
rumbero
#62 Post by rumbero » Sun Nov 20, 2011 3:45 am
ZaZ wrote:it's been my experience for most users, vertical resolution is more important.
Quite a few of my colleagues have resorted to turn their external widescreen monitors by 90 degrees in order to have a better vertical view for their work tasks. While this may sound silly, it actually makes a lot of sense for some work contexts.
#63 Post by pianowizard » Sun Nov 20, 2011 11:51 am
dr_st wrote:Glossy coating can make a dull screen look somewhat better. It definitely makes colors look more vibrant and improves perceived contrast. Some say it even makes the viewing angles a bit wider, although I haven't verified that. Under it I am pretty sure that, on average, it's the same crappy TN panels.
I believe you are correct about this. For instance, my Samsung 2343BWX and Dell sp2309w monitors probably use the same 23" 2048x1152 panel, but because the Samsung is matte while the Dell is glossy, images on the Dell look somewhat more pleasing.
dr_st wrote:I for one view everything in full screen mode. I hate horizontal scrolling, and unfortunately, to have no horizontal scrolling and still enough usable horizontal space for two windows side-by-side you need at least 2048 (twice XGA).
For screens narrower than 2048, I partially overlap the two windows.
To me, vertical and horizontal are more or less equally important and that's why 1920x1200 is my favorite laptop resolution: it's as tall as 1600x1200 and as wide as 1920x1080. For a long time I tried to like 2048x1536 but eventually gave up because its pixel density on a 15.0" screen was just too high.
rumbero wrote:Quite a few of my colleagues have resorted to turn their external widescreen monitors by 90 degrees in order to have a better vertical view for their work tasks. While this may sound silly, it actually makes a lot of sense for some work contexts.
I don't find this silly at all because I have been doing it for over 3 years. Have you seen the photo of my computer/monitor setup in my office: http://forum.thinkpads.com/viewtopic.php?t=52525 .
ZaZ
moderator
moderator
#64 Post by ZaZ » Sun Nov 20, 2011 12:10 pm
I used to have a Dell 2001FP turned sideways. It was great for things like Office and Internet. My other panel was a junk TN panel. I decided to replace it and bought a Samsung 2333T. The 2333T is great, but when I put it next to the Dell, I realized how old and yellowed it had gotten over the years. I bought another 2333T to replace it cause they were so cheap at the time. It can't go sideways and 1080 isn't wide enough for FF with the sidebar, but I do miss the 1600 vertical resolution.
E7440
#65 Post by dr_st » Sun Nov 20, 2011 1:15 pm
20" 4:3 is probably the best size and form factor for portrait mode. While it is possible to achieve even greater vertical space with 24" widescreens, as pianowizard demonstrates, the screen results being too tall for comfortable view at typical distance without significant neck/eye motion, which of course ends up in strain.
But in general, I have a problem with anything in portrait mode, because the Cleartype-style subpixel rendering, which make text look so much smoother in general, don't look as good on it (being tailored to specific subpixel orientations).
BTW, I also have one of these 20" monitors, albeit the 2007FP, which is about 3.5 years old now, and it does have some yellowing on one side. Still a great screen, though.
#66 Post by pianowizard » Mon Nov 21, 2011 11:01 am
dr_st wrote:While it is possible to achieve even greater vertical space with 24" widescreens, as pianowizard demonstrates, the screen results being too tall for comfortable view at typical distance without significant neck/eye motion, which of course ends up in strain.
24" is indeed a bit too tall, even at arm's length from my eyes (which is the distance that I use). However, there are a few 22" 1920x1200 monitors e.g. the Lenovo L220X, and you might find these not too tall.
BTW, I have come across some 27" 2560x1440 monitors that can be turned into portrait!
Matthew_Greening
Are there really three different Lenovo HD+ panels?
#67 Post by Matthew_Greening » Fri Dec 09, 2011 7:29 am
ssd_thinkpad wrote:There are - to my knowledge - three different HD+ panels build-in from lenovo in the T520 and W520. One of this panels is a very bad one. Here are two tests about the HD+ and the FHD panel with real data. Not that kind of "I like this display" but they measured the display:
http://www.notebookcheck.net/Review-Len ... 596.0.html
http://www.notebookcheck.net/Review-Len ... 220.0.html
I was about to buy the L520 with HD+ as I have read that it has the same display as the T520 reviewed by NotebookCHECK. Both reviewed panels seem decent.
Which is the "very bad" HD+ panel and how does one recognise it without relying only on perception?
According to the FRU numbers it should be the same display in the T520 and L520:
http://support.lenovo.com/en_GB/product ... PD011130#8
http://support.lenovo.com/en_GB/product ... 008483#HD+
ThinkRob
Re: Are there really three different Lenovo HD+ panels?
#68 Post by ThinkRob » Fri Dec 09, 2011 11:32 am
Matthew_Greening wrote:Which is the "very bad" HD+ panel and how does one recognise it without relying only on perception?
If you can't easily tell which is "bad" just by looking at it, wouldn't that mean that it's not bad after all?
Current laptop: X1 Carbon 3
Current workstation: none
Matthew_Greening
#69 Post by Matthew_Greening » Fri Dec 09, 2011 1:58 pm
ThinkRob wrote:If you can't easily tell which is "bad" just by looking at it, wouldn't that mean that it's not bad after all?
I'm sure I could when I had the three HD+ panels next to each other but I'm more likely to compare whatever I get with my current 1200x800 display. I hope that even the worst of the three Lenovos HD+ panels would be better than my current one therefore it might be difficult to spot that I get a relatively bad deal.
thinkpadgeek91
#70 Post by thinkpadgeek91 » Mon Jan 02, 2012 1:08 am
I'm a big T series fan but it's totally up to you. My T410 rocks. But I'm waiting for next year to upgrade to a T530. 15" HD screen= :D
ThinkPad T410s 2 4Ghz Core i5;8GB:160GBSSD Linux Mint.
Thinkpad T61 2.4Ghz Core2Duo;4GB;250GB;Linux Mint
ThinkRob
#71 Post by ThinkRob » Wed Jan 04, 2012 9:59 am
Matthew_Greening wrote:I'm sure I could when I had the three HD+ panels next to each other but I'm more likely to compare whatever I get with my current 1200x800 display. I hope that even the worst of the three Lenovos HD+ panels would be better than my current one therefore it might be difficult to spot that I get a relatively bad deal.
Ah, I see.
Personally, I'm almost always able to make a comparison between LCDs when I'm looking at them side-by-side. It's rare, though, that I'll find a panel remarkable in one way or the other when viewing it on its own. There are some exceptions to this -- the X301 had a remarkably low-contrast screen, and the WSXGA+-equipped T500/15.4" T61s a remarkably good one -- but for the most part I don't tend to notice the screen quality unless I'm doing a side-by-side comparison.
I suspect that most business (i.e. non-multimedia) users are like this; we don't really care too much about inspecting the quality of the screen since we're usually focused on what it's displaying. :D
rleo25
#72 Post by rleo25 » Wed Jan 18, 2012 9:04 pm
I would recommend any of the Thinkpad series according to your special needs, high quality, durability and premium keyboards make any of these a good choice.
