Lion Mac OS X 10.7 on Thinkpad X61
Pirmas
Re: Lion Mac OS X 10.7 on Thinkpad X61
#121 Post by Pirmas » Wed Jan 04, 2012 4:24 am
[quote=It worked for me after booting linux / windows and enabling it from there.[/quote]
Any other solutions to enable bluetooth? I dont have other OSs installed..
X61T 7767-96U 4GB ram. Lion 10.7.0 OS
victor.vhv
#122 Post by victor.vhv » Wed Jan 04, 2012 1:34 pm
Pirmas wrote: Any other solutions to enable bluetooth? I dont have other OSs installed..
Maybe creating a bootable usb linux stick?
It's some kind of ACPI issue, so maybe there is a way to patch the DSDT or something like that...
Thinkpad X61 Tablet 7763-CTO 4GB RAM
Processor: 1.79 Ghz Intel C2D
Graphics: Intel GMA 965 (0x8086, 0x2a02), 1400x1050
WI-FI: Apple Airport Extreme (0x168C, 0x0024 - Atheros 5416 4.0)
Disk: SAMSUNG 640GB HM641JI GPT
OS:Mac OS X Lion 10.7.3 (11D46), Chameleon r1664, tri-boot Ubuntu+W7
Pirmas
#123 Post by Pirmas » Wed Jan 04, 2012 2:28 pm
Yes, I tried that, booted from cd ubuntu, bluetooth was activated, then booted Lion and bluetooth was there, but screen was flickering, some problems with video, after shutdown, I disabled bluetooth, booted up ok, and then switched the bluetooth back... Bluetooth is ok now. Very strange....
Pirmas
#124 Post by Pirmas » Thu Jan 05, 2012 11:45 am
Anastasius wrote:BTW, it seems the problem with processor heat fixed itself. After several reboots CPU Heatsink temp is around 60-65C. Even lower than on Snow Leopard!
crashnburn Vanilla Retail 10.6.3 > Tweaks/ Kexts > Update 10.6.7 should work. Check the Sebinouse guide for Snow Leopard.
What program you use to see the temp of the CPU? I use iSTAT 2, and get just hdd temp. No cpu info.
smittoid
#125 Post by smittoid » Thu Jan 05, 2012 2:13 pm
Hi everyone,
This has been an invaluable thread and discussion. I have an interesting scenario that I am trying to troubleshoot and am hoping someone can provide some insight.
My system:
X61t (Tablet)
7763-CU8, with an L7500 processor, X3100 graphics, and 4MB of RAM.
Airport Extreme 0x168C, 0x58A (Atheros 5212 a/b/g card)
I've had Snow Leopard on this machine all the way through 10.6.8
Recently installed Lion 10.7.2 using Anastasius instructions and files at the beginning of this thread.
Everything works really well on startup. Machine is really fast. Using Anastasius' files, and iStat v2, I can monitor CPU Heatsink, Mem controller, and Northbridge temperatures, plus the fan speed. CPU Heatsink temp runs between 60 and 75 degrees, depending on what I am doing (video, etc).
The
ioreg -lw0 | grep CSTInfo
command returns a value: 19136773 so I assume my CStates are enabled and working.
My SMBIOS.plist and DSDT.aml are the same as Anastasius' - SMBios using the MacBookPro 2,3 profile. I am booting with Chimera 1.6.
Issues outstanding:
** I used to be able to monitor CPU0 and CPU1 independent temperatures using a different FakeSMC.kext which included ACPIMonitor and IntelCPUMonitor. I can swap my older FakeSMC to get these back, but I am wondering what others are getting for temp monitoring with Anastasius files.
** When I put the machine to sleep and resume it, I have an issue with video slowness in the browser. I can reproduce this every time - start up clean, go to Youtube, play a particular video in 720p - works fine. Sleep / Resume, it is choppy every time.
** I am also seeing an odd kernel log message: "failure to load kext.com.apple.driver.AppleIntelGMAX3100" - Couldn't alloc class "Intel965" - which seems odd since I have a different GPU....
** Bluetooth worked when I built the machine, however it seemed to try to enumerate "all" bluetooth addresses starting with 00:00:00:01 and scanned everything in the universe. The bluetooth process was thrashing as a result, so I disabled it.
This machine is superb as a little Mac - especially with the Tablet features, etc. I am just hoping to iron out these last wrinkles. Any thoughts on these issues would be hugely appreciated - especially the sleep / resume choppiness.
victor.vhv
#126 Post by victor.vhv » Fri Jan 06, 2012 6:01 am
smittoid wrote: ** I am also seeing an odd kernel log message: "failure to load kext.com.apple.driver.AppleIntelGMAX3100" - Couldn't alloc class "Intel965" - which seems odd since I have a different GPU....
I got strange messages in my machine when using Chimera, using always the latest Chameleon from their buildbot works perfectly for me (getting it with champlist too).
By the way, I've been for some days without crashes now, i'm using the macbook3,1 profile, and all of anastasious' files.
Pirmas
#127 Post by Pirmas » Fri Jan 06, 2012 7:21 am
Can you tell me is this wifi card model supported by Mac os or not?
IMG_20120105_180026.jpg - 593.5 Kb
victor.vhv
#128 Post by victor.vhv » Fri Jan 06, 2012 7:27 am
Pirmas wrote:Can you tell me is this wifi card model supported by Mac os or not?
There is a project called iwidarwin with intel wireless drivers for mac osx, but I don't think the intel 3945ABG is supported under lion (it seems that they dropped development since 10.5), i had to replace my intel 4695AGN with a cheap Atheros from ebay (Apple Airport Extreme (0x168C, 0x87 - Atheros 5416 4.0)).
smittoid
#129 Post by smittoid » Fri Jan 06, 2012 4:23 pm
Thanks victor.vhd! The latest chameleon definitely made a difference.
After reinstalling chameleon I also methodically re-installed every kext from the first posting, and my sleep / freeze issues appear to be gone. I am still working with the MacBookPro2,3 profile as it seems to be working.
Looking through my kernel logs, I am also seeing 3 audio assertions. Audio is working, but I haven't tried anything fancy like plugging in a line input or headphones out.
Sound assertion "0 == fMikeyDriver" failed in "/SourceCache/AppleHDA/AppleHDA-162.1.37/AppleHDA/AppleHDADriver.cpp" at line 1063 goto handler
Sound assertion "0 != result" failed in "/SourceCache/AppleHDA/AppleHDA-162.1.37/AppleHDA/AppleHDAPath.cpp" at line 1175 goto Exit
Sound assertion "0 != pathSet->getWidgetAmplifierGainRange ( &zeroValue, &minValue, &maxValue, &minDB, &maxDB, kPATH_CONTROL_SPATIAL_CHANNELID_Master )" failed in "/SourceCache/AppleHDA/AppleHDA-162.1.37/AppleHDA/AppleHDAEngine.cpp" at line 266 goto handler
Pirmas
#130 Post by Pirmas » Sat Jan 07, 2012 7:29 am
I sometimes get this unusable screen view. After reboot or sleep. Anybody had this? How to fix?
http://www.failai.lt/djqo51gagd69/IMG_2 ... 225408.jpg
Pirmas
#131 Post by Pirmas » Sat Jan 07, 2012 4:28 pm
[quote=There is a project called iwidarwin with intel wireless drivers for mac osx, but I don't think the intel 3945ABG is supported under lion (it seems that they dropped development since 10.5), i had to replace my intel 4695AGN with a cheap Atheros from ebay (Apple Airport Extreme (0x168C, 0x87 - Atheros 5416 4.0)).[/quote]
I found different atheros cards, but not the one you wrote about. Do you have a link where you got it?
victor.vhv
#132 Post by victor.vhv » Sat Jan 07, 2012 5:01 pm
Primas wrote:I found different atheros cards, but not the one you wrote about. Do you have a link where you got it?
Just do a quick Search in eBay airport extreme minipcie' there should be plenty of míni pci-e cards.
I'll add a link once I get home.
Pirmas
#133 Post by Pirmas » Sat Jan 07, 2012 5:19 pm
victor.vhv wrote:I found different atheros cards, but not the one you wrote about. Do you have a link where you got it?
Just do a quick Search in eBay 'apple airport extreme'there should be plenty of míni pci-e cards.
I'll add a link once I get home.[/quote]
thanks
tcone
#134 Post by tcone » Sat Jan 07, 2012 5:57 pm
The AR9280 is cheap and great. Works out of the box, runs under Win/Linux and of course OSX. This one only needs 2 antennas and has very efficient powermanagement. No hot palmrest :)
X61 T7300 SXGA+@2.93GHz (HV121P01-101!) 160GB X25-M AR9280 | X61 7674-GS3 | X61 T7300 ul-panel 4965AGN | X60s L2400 SXGA+ WD5000BEVT AR5008 pcie-/sim-card mod | T41 1,7@2,26GHz | R32 | 240x | 570
Pirmas
#135 Post by Pirmas » Sun Jan 08, 2012 4:05 am
tcone wrote:The AR9280 is cheap and great. Works out of the box, runs under Win/Linux and of course OSX. This one only needs 2 antennas and has very efficient powermanagement. No hot palmrest :)
thanks. does bluetooth work with this, no conflicts?
Geraldo
#136 Post by Geraldo » Sun Jan 08, 2012 7:54 am
Hi all,
thanks for that Wifi card tip. I just ordered one. Airdrop seems to be also working with that card, which is great. Ill test and share experiances.
I also have a question: I own a x61 Tablet now. I added ssd, a sierra 8775 and ram. I really have no problems at all, everything works well. Only one thing bothers me. My model has a multitouch screen. TabletMagic only enables pen input. I tried the touch base driver (theres a driver for IBM FlipTouch, I guess it should be my screen) but without any luck. If I install both of these i don't have any tablet input at all. Tabletmagic and touch base don't seem to like each other a lot. Does any one has any idea? Would be great! Thank you!
Geraldo
X61 T8100, 64Gb Samsung SSD, Sierra Wireless MC8775, 4GB Ram, Atheros AR5008
victor.vhv
#137 Post by victor.vhv » Mon Jan 09, 2012 3:55 am
Geraldo, I had to enable airdrop on all interfaces to get it to work, running the following command:
defaults write com.apple.NetworkBrowser BrowseAllInterfaces 1
Found at http://www.digitalmarketingtalk.com/apple/how-to-enable-airdrop-on-your-hackintosh-over-ethernet-or-wi-fi/
smittoid wrote: After reinstalling chameleon I also methodically re-installed every kext from the first posting, and my sleep / freeze issues appear to be gone. I am still working with the MacBookPro2,3 profile as it seems to be working.
Did you have any crashes with the MacBookPro2,3 profile? I understand things might go a bit faster than when using the MacBook3,1 profile.
vespolibelt
#138 Post by vespolibelt » Mon Jan 09, 2012 9:53 am
Good Morning,
I recently purchased a totally rad X61 for a triple-boot project.
Question: Will OSX recognize and utilize the full 8gb of ram possible with 64-bit Windows 7?
I will be using OSX partition primarily, and would like to know if it's worth the extra paper for 8gb over 4gb.
Geraldo
#139 Post by Geraldo » Mon Jan 09, 2012 3:20 pm
@victor: Thanks for the hint.
About the ram question,
I don't think ram is the bottleneck on these older machines. Its more the cpu which is quite slow compared to the new intel i3/i5/i7 generation. I would suggest to rather invest in a ssd or a hybrid drive (seagate moments xt).
I installed lion on a x61. I faced some sleep problems in the beginning. just go trough this thread, its all in here.
Have fun.
Gerald
Anastasius
#140 Post by Anastasius » Mon Jan 09, 2012 7:00 pm
Pirmas wrote:What program you use to see the temp of the CPU? I use iSTAT 2, and get just hdd temp. No cpu info.
iStat menus 2. You'll need my DSDT and FakeSMC with plugins installed for monitoring. All of these are included in my package from the first post.
Geraldo wrote: I tried the touch base driver (theres a driver for IBM FlipTouch, I guess it should be my screen) but without any luck. If I install both of these i don't have any tablet input at all. Tabletmagic and touch base don't seem to like each other a lot. Does any one has any idea? Would be great! Thank you!
There's a driver for finger touch. It costs about $200 so I don't remember its name :) The price is too high for me for a thing that I use very rare. But please write here if you find any other solution!
smittoid
#141 Post by smittoid » Tue Jan 10, 2012 10:09 pm
So far no crashes - seems really stable at this point. Am looking now for a wifi card that can support 802.11n - since it seems like there still is no solution for the Intel 4965agn that I had to swap out of it....
smittoid
#142 Post by smittoid » Tue Jan 10, 2012 10:39 pm
Anastasius - thanks so much for all of the time you have put into this and the 10.6.x efforts. These machines are so great and OSX breathes a lot of new life into them.
Just had a quick question about the CPU temp monitoring:
Anastasius wrote: iStat menus 2. You'll need my DSDT and FakeSMC with plugins installed for monitoring. All of these are included in my package from the first post.
In an earlier thread, it was noted that we need to install SMCITEController.kext to FakeSMC's Plugins folder:
jzhang18 wrote: I know for sure, iStat Menu needs SMCITEController.kext. so I cannot simply remove it.
Any fix for it? really appreciated!
Anastasius wrote: You need to put to PlugIns folder of FakeSMC.
I just tried moving SMCITEController.kext into FakeSMC (plugins) using the files from your package - I am getting the Heatsink temp, but not the individual CPU's.
My FakeSMC plugins now contain
ACPIMonitor.kext
No joy. When I had it working with a different FakeSMC, it had an additional plugin - IntelCPUMonitor.kext - it seemed like that was the difference for 10.6.x....
Geraldo
#143 Post by Geraldo » Wed Jan 11, 2012 1:25 pm
@Anastasius
Im just writing email with them back and forth. Im waiting for a special version of the driver which is supposed to allow pen & finger input. Well see. If everything works ill ask for a discount. But lets see how it goes first. Ill keep you updated.
BTW: How about your work on the driver update. Will we see some soon? =)
Geraldo
bense
#144 Post by bense » Wed Jan 11, 2012 6:17 pm
I'mmmmm baccckkkkkk :D
Previously I had been following this thread because of my R61e, but I have just purchased a x61 tablet for a good price :D
Any of you guys have the tablet working with the stylus? Did you have to do anything after installing TabletMagic?
When I was taking apart my x61t before, I noticed that there is an extra, empty MiniPCIE slot. Have any of you looked into using the Broadcom BCM970015 ? Its what the xbmc people are installing in their 1st gen AppleTV's to get 1080p working. http://www.logicsupply.com/products/bcm970015
Here is a link to the osx driver http://code.google.com/p/crystalhd-for-osx/
Geraldo
#145 Post by Geraldo » Wed Jan 11, 2012 7:55 pm
Hey bense,
welcome back!
Just use tablet enabler and Tablet magic. For me it worked just fine.
its true. Theres an open slot. I placed a sierra mc8775 3G modem in there. To be able to use non Lenovo hardware you need to whitelist the bios. Google for the middleton bios hack for x61t. It will also enable Sata II.
Also theres no good way to get bluetooth running in the sense that you can disable it software wise in mac os. It will turn off though when using the hardware switch. What i did is to tape a pin of the mini pci-e wlan card. That way it won't shut down when using the switch, but bluetooth will. You can still disable wlan in mac os though.You will also have to do that with your broadcom card, otherwise it will power of with bluetooth when you use the switch.
I wonder if I can jank out the modem mini pci-e half size card to place the broadcom decoder there. What do you guys think? Good idea?
Geraldo
Anastasius
#146 Post by Anastasius » Thu Jan 12, 2012 9:56 am
Geraldo wrote: Im just writing email with them back and forth. Im waiting for a special version of the driver which is supposed to allow pen & finger input. Well see. If everything works ill ask for a discount. But lets see how it goes first. Ill keep you updated.
Geraldo
Very cool!
I will try to post driver update as soon as possible. I'm too busy these days. The problem is VoodooPS2Controller doesn't work in my current configuration - but I know how to fix it, just need some free time.
smittoid wrote: No joy. When I had it working with a different FakeSMC, it had an additional plugin - IntelCPUMonitor.kext - it seemed like that was the difference for 10.6.x....
You need also to use my DSDT to have all sensors enabled.
Pirmas
#147 Post by Pirmas » Fri Jan 13, 2012 5:13 am
33!mport wrote:Hello everybody !
I'm new in osx68 world, and have some issues ! :( :)
When I boot from the install usb stick on my X61T, i have a kernel panic :
panic(cpu 0 caller 0x672901): "Unable to find driver for this platform: \"ACPI\".\n"@/SourceCache/xnu/xnu-1699.22.73/iokit/Kernel/IOPlatformExpert.cpp:1504
Update: i haven't restored the correct .dmg on my usb stick, now it's ok.
I am having the same issues while trying to make a bootable usb. The same panic message. Wonder what can it be? I have Lion 10.7.0 dmg file, from working leopard system restored a dmg to usb, installed chamelion... placed extra folder on it... Any sugestions why this panic "Unable to find driver for this platform: \"ACPI\".\n"@/SourceCache/xnu/xnu-1699.22.73/iokit/Kernel/IOPlatformExpert.cpp:1504 ?
vespolibelt
#148 Post by vespolibelt » Fri Jan 13, 2012 1:17 pm
|2) Install Chameleon 2.0 RC5 r1496 (you need exactly this version or Chimera - read below) to that Flash (it can be installed from .pkg)
3) Copy /Extra folder from installed 10.6.7 (included below in this post) to Flash|
Model X61: 7673
When I copy the /Extra folder Anastasius attached to the first post, I find that Chameleon has already installed an Extra Folder. Should I merge or overwrite this?
I am taking care to follow the steps. Lucky me to be stuck at step 4 :roll:
bense
#149 Post by bense » Mon Jan 16, 2012 2:46 pm
Geraldo wrote:Just use tablet enabler and Tablet magic. For me it worked just fine.
Geraldo
I now have TabletEnabler and TabletMagic both. Previously I had forgotten to add TabletEnabler. I added WACF008 to both
LegacyX60T.kext/Contents/Info.plist
and
/System/Library/Extensions/Apple16X50Serial.kext/Contents/PlugIns/Apple16X50ACPI.kext/Contents/Info.plist
So now TabletMagic sees 'serial0' for port. (Previously WACF004 did not get serial0 to show up)
I am using TabletMagic 2.0b18 and have tried tinkering with just about every single option yet I cannot get the stylus to control the mouse :(
I am on 10.7.1
x61t - 7762
Also using the middleton BIOS like you mentioned :D (Had to install winxp on a spare drive because the CDROM that I burned would not accept the USB CDROM Drive :( )
More information about my tablet setup can be seen in post 7 of this thread:
http://honda-tech.com/showthread.php?t=3000241
As you can see, I have removed the internal wifi module so that I don't get distracted with the internet/computers when I'm trying to do my homework. I also purchased a modular Rosewill MiniN1 usb wireless card, for the occasions that I do want wifi capabilities with this x61
Using the VoodooSDHC.kext (the one from the MAC PNT 02 15 2011 package) and placing it in /Extra/Extensions, then running a kext utility has allowed me to get the SD slot working. I have tested it with both SD and SDHC cards.
Pirmas
#150 Post by Pirmas » Mon Jan 16, 2012 3:07 pm
The eaby item says "This card compatibles with most of the notebooks with mini pci-e interface except IBM, HP machines. " is it true? Do you have exactly this model in your x61t?
