Lion Mac OS X 10.7 on Thinkpad X61
Anastasius
Re: Lion Mac OS X 10.7 on Thinkpad X61
#91 Post by Anastasius » Tue Nov 29, 2011 3:56 pm
Great Gatsby wrote: Which is a real pity, because IMHO FileVault 2 is the killer feature of Lion (all the others are rather not features I've been deeply missing in Snow Leopard so far :|).
Yeah, I'm itching to use it and still not found the way as well :(
jzhang18 wrote: I know for sure, iStat Menu needs SMCITEController.kext. so I cannot simply remove it.
Any fix for it? really appreciated!
You need to put to PlugIns folder of FakeSMC.
Geraldo wrote: Its funny. I don't have any problems with these freezes at all.
I have freezes only in a very high load situation on Graphics - when I run at the same time Skype, Trillian, uTorrent, editing text in Pages with graphics, watch 1080p video on YouTube and browse a site which uses Safari's hardware openGL acceleration (CSS WebKitTransform *). It's a rather rare situation, but it's real.
jzhang18
#92 Post by jzhang18 » Tue Nov 29, 2011 7:06 pm
That error is gone after I move it to PlugIns folder of FakeSMC but some other error messages appears as:
kernel: kxld[org.mozodojo.TheOnlyWorkingITESMCController]: The following symbols are unresolved for this kext:
kernel: kxld[org.mozodojo.TheOnlyWorkingITESMCController]: 	__Z13FakeSMCAddKeyPKcS0_hPc
kernel: kxld[org.mozodojo.TheOnlyWorkingITESMCController]: 	__Z13FakeSMCAddKeyPKcS0_hPcP14FakeSMCBinding
kernel: kxld[org.mozodojo.TheOnlyWorkingITESMCController]: 	__Z13FakeSMCAddKeyPKchPc
kernel: kxld[org.mozodojo.TheOnlyWorkingITESMCController]: 	__Z14FakeSMCReadKeyPKc
kernel: kxld[org.mozodojo.TheOnlyWorkingITESMCController]: 	__Z23FakeSMCRemoveKeyBindingPKc
kernel: Can't load kext org.mozodojo.TheOnlyWorkingITESMCController - link failed.
kernel: Failed to load executable for kext org.mozodojo.TheOnlyWorkingITESMCController.
kernel: Kext org.mozodojo.TheOnlyWorkingITESMCController failed to load (0xdc008016).
I saw this error message exists in Kernel Log, it might be related to above issue
kernel: Kext com.apple.driver.AppleIntelGMAX3100 - library kext com.apple.iokit.IOGraphicsFamily not found.
kernel: Can't load kext com.apple.driver.AppleIntelGMAX3100 - failed to resolve library dependencies.
kernel: Kext com.apple.driver.AppleIntelGMAX3100 failed to load (0xdc00800e).
kernel: Failed to load kext com.apple.driver.AppleIntelGMAX3100 (error 0xdc00800e).
X61 T8300 4GB Lion 10.7.3
Geraldo
#93 Post by Geraldo » Wed Nov 30, 2011 1:12 pm
Hey ho,
good to see you guys working on improvements. I finally would the reason for my not working bluetooth. I deactivated it in Access Connections last time I booted to windows. So went the, activated, changed hard drives and that was it. =)
Alle the best!
Geraldo
X61 T8100, 64Gb Samsung SSD, Sierra Wireless MC8775, 4GB Ram, Atheros AR5008
Anastasius
#94 Post by Anastasius » Wed Nov 30, 2011 3:49 pm
jzhang18, thanks for the info and please hold on!
I'm working on a modified version of my X61T package that will get rid of graphics and SMC errors. Hopefully will release it soon.
Geraldo, jzhang18, guys
How does SSD feel itself on Lion and X61? Does it get approved by BIOS? Any side issues?
I'm thinking about buying an SSD, but I heard about many problems with older Lenovo hardware....
Geraldo
#95 Post by Geraldo » Wed Nov 30, 2011 4:25 pm
Hey,
Can only talk about performance gain under Windows xp since i never tried mac os with the old hdd. It cut boot time by half and also over all system performance was much better. I didnt have any bios problems at all. Old one out Samsung in and that was it. Mac os recognizes the drive as an ssd. You need to activate trim support via terminal though. Also the x61 becomes very quiet of course. Only thing I still have problems with is sleep. But that might also be caused by my not jet properly installed sierra wwan card. Will edit drivers next week in order to fix that and than post results.
Cheers
jzhang18
#96 Post by jzhang18 » Thu Dec 01, 2011 10:40 am
I am using intel and Kingston SSD. Both are SATA II, x61 only uses SATA I, but I did not encounter any problem, BIOS recognized both correctly.
Booting is faster with SSD vs 7200rpm HD (cut half of the time), SSD is quiet, iStat Menus v3 shows my Kingston SSD is 33 ℃ under normal use.
Trim needs to be enabled manually with this instruction:
http://digitaldj.net/2011/07/21/trim-enabler-for-lion/
I also tested with Trim Enabler v1.2, it works. but it seems better using above manual method.
I have no sleep and CMOS reset issue after I patched AppleRTC.kext from instruction of Anastasius's 1st post.
Most heavy duty practical test is playing StarCraft II on x61 for a few of hours . almost no crash with Lion 10.7.2 (but randomly crashes under Snow Leopard 10.6.8 )
Heavy duty CPU test is using Prime95 for MAC (http://mersenne.org/freesoft/), I only tested 1 hour, nothing is wrong with Lion 10.7.2 (T8300, 8GB RAM)
victor.vhv
#97 Post by victor.vhv » Sat Dec 03, 2011 9:08 pm
Anastasius wrote:jzhang18, thanks for the info and please hold on!
I'm waiting anxiously for a new update on this! :P I've been trying dofferent serials and macbook models with no luck :-(
Thinkpad X61 Tablet 7763-CTO 4GB RAM
Processor: 1.79 Ghz Intel C2D
Graphics: Intel GMA 965 (0x8086, 0x2a02), 1400x1050
WI-FI: Apple Airport Extreme (0x168C, 0x0024 - Atheros 5416 4.0)
Disk: SAMSUNG 640GB HM641JI GPT
OS:Mac OS X Lion 10.7.3 (11D46), Chameleon r1664, tri-boot Ubuntu+W7
tcone
#98 Post by tcone » Sat Dec 03, 2011 9:42 pm
jzhang18 wrote:Both are SATA II, x61 only uses SATA I, but I did not encounter any problem, BIOS recognized both correctly.
Install the middleton bios and you will have full sata2 speed. I'm running an intel postville g2 with some filesystem optimizations and haven't seen any problems/bottlenecks with or without trim support so far. But I'm a triple booter (W7/Linux/OSX) so I can't really tell if it makes a huge difference to run an ssd without trim on a mac-only system.
Performance makes a huge difference with sata2, even if some people claim you wouldn't notice it.
X61 T7300 SXGA+@2.93GHz (HV121P01-101!) 160GB X25-M AR9280 | X61 7674-GS3 | X61 T7300 ul-panel 4965AGN | X60s L2400 SXGA+ WD5000BEVT AR5008 pcie-/sim-card mod | T41 1,7@2,26GHz | R32 | 240x | 570
jzhang18
#99 Post by jzhang18 » Tue Dec 06, 2011 12:15 pm
What I didn't test yet
- SD card drivers
SD card driver works under Lion 10.7.2, with some minor flaws
download the driver from http://forum.voodooprojects.org/index.php?topic=972.0
unzip VoodooSDHC_32or64.kext.zip, install it with KextBeast, then run Kext Utility to refresh system cache.
some minor issues noticed as:
Booting Lion with SD card inserted, I saw 2 mounted volumes of SD card. ejecting only one volume might crash OS. better to eject them all.
Sometime, it might slow down shutdown process with SD inside card reader (booting seems OK).
I tested 150x 4GB SD card and 133x 4GB SDHC, Class-6 16GB SDHC -- 3 cards
All work, I put AVCHD MTS video files on SD card, play it with VLC or Roxio Video Palyer, speed is acceptable! (some frames dropped, but OK, both cores of my T8300 went 98%, MTS file needs heavy decompression for every video frame during playback).
Geraldo
#100 Post by Geraldo » Wed Dec 07, 2011 1:52 pm
Hey guys,
I got my sierra MC8775 3G Module working. Its not that hard to do.
-Install the card in the mini pcie slot
-Go to the sierra website and download drivers for the sierra AirCard 880E (compatible to the mc 8775)
-Install those and reboot
-Go to /s/l/e and search for sierra kexts and copy all three kexts to desktop
-uninstall the driver (sierra watcher, all you need is the kexts)
-check the device-id in system profile of the card (recognized as usb mini card)
-covert device ids from hex into decimal numbers (ask google)
-instert decimals into plist files of the sierra kexts in the mc8775 section (plist is found in the content folders in the kext files)
-copy kexts back to /s/l/e and replace existing ones
-repair permissions via kext utility and reboot
Now the device should be recognized correctly in the network section. Now find out the apn for your provider. It took me
some time to find the right configuration but now it works very well.
I tried to fix brightness with the custom x3100 driver which tcone linked to. All it did was wrecking my system. Any other ideas how to fix brightness controls? Also I cant deactivate bluetooth. How do I tackle that?
EDIT: Heres a link to the edited kexts for sierra mc8775.
cataily
#101 Post by cataily » Sat Dec 10, 2011 12:57 am
who can help me to get the Trackpoint/PS/2 Keyboard driver for x61.
in my case, I only can use keyboard ,but the trackpoint doesn't work.
thanks.
victor.vhv
#102 Post by victor.vhv » Sat Dec 10, 2011 5:36 am
cataily wrote:who can help me to get the Trackpoint/PS/2 Keyboard driver for x61.
thanks.
Cataily, I have it working with Anastasius' kexts, you can get them on the first post.
Those kexts are in the SLE.zip package:
AppleACPIPlatform.kext
AppleHDA.kext
AppleIntelGMAX3100FB.kext
IOPlatformPluginFamily.kext
Intel82566MM.kext
TabletEnabler.kext
ThinkpadHotkeyController.kext
VoodooBattery.kext
VoodooPS2Controller.kext
VoodooTSCSync.kext
cataily
#103 Post by cataily » Sat Dec 10, 2011 11:41 am
thanks victor.vhv,but it didn't work.
victor.vhv
#104 Post by victor.vhv » Sat Dec 10, 2011 11:54 am
cataily wrote:thanks victor.vhv,but it didn't work.
Do you have the /Extra as the first post as well? Is your machine a X61 Tablet?
Geraldo
#105 Post by Geraldo » Sat Dec 10, 2011 9:06 pm
Hey guys,
Im using my x61 now every day and its doing a great job. But theres still no sleep. Also I found out, that C-States are not working. Im using all of Anastasius files (Extra Folder and SLE) but no luck.
When I try to put the X61 to sleep, the Moon turns on&off for about 3-5 Sekonds. Then a beep occurs and it powers off. Then waking up it just reboots. Chamaleon is stating an error "Header read size 200 - Incorrect Image Signature" and thats it.
Do you have any Ideas?
Geraldo
cataily
#106 Post by cataily » Sat Dec 10, 2011 10:33 pm
I have the X61 but it is not the tablet.
and I use iATKO 10.7.2 to install. I didn't do anything on the install disk. when it's done,the keyborad is ok, just missing the trackpoint.
and I installed the Anastasius' kexts,but nothing happen.
thanks~
Geraldo
#107 Post by Geraldo » Sun Dec 11, 2011 6:16 am
Hey,
I also use an x61. I installed 10.7.0 via a pendrive. Then installed Anastasius /S/L/E vis kext utility added the extra folder and repaired permissons. Then the combo update to 10.7.2. Everything except sleep and c-States. Must be rather because of my different hard drive, the sierra card oder wlan card or the extra ram. But I don't have any clue where to start.
Winter wishes,
Geraldo
jzhang18
#108 Post by jzhang18 » Sun Dec 11, 2011 9:30 am
I tested a few of installation methods on my x61, include above DVD.
But I feel the best installation is --
choose UniBeast and 8GB USB flash drive to create bootable Lion flash drive. http://tonymacx86.blogspot.com/2011/10/ ... using.html.
Do not forget to choose "Laptop Support" when creating it. so that during installaton, x61 keyboard is working for you!!!
After it finish installation, install MultiBeast Lion Edition. http://tonymacx86.blogspot.com/2010/02/ ... ation.html
Choose "UserDSDT install" (do not forget to copy x61 DSDT file to your desktop), choose "FakeSMC", "32-bit Apple Boot Screen", "Chimera v1.6" as boot loader.
After installation, do not reboot, just copy all necessary Kexts file from first post into E/E and S/L/E.
using Kext Utility to repair the permission. using smbios.plist I posted in this thread.
Then reboot. a fully working x61 should be there for you!
cataily
#109 Post by cataily » Sun Dec 11, 2011 8:42 pm
thanks jzhang18, and where can i get the x61 DSDT? or you made it yourself? I can't find on the tonymacx86's DSDT database.
Geraldo
#110 Post by Geraldo » Mon Dec 12, 2011 10:29 am
Okay...
I got C-States working after a clean install. Also found out that 1) the pin to tape is not the marked pin on top of the card, but the one undr it. 2) I only get an answer using the old terminal command for c-states stated in the X61 SL Thread, the new one out of this thread does not work for me. If c-states wouldn't work my cpu temperature should be round about 71C° which they aren't and my machine runs quite n cool so I guess they are working.
Everything is in place now exempt two thing. 1) Sleep 2) brightness control
1) sleep: To get it work I tried this http://forge.voodooprojects.org/p/chameleon/issues/133/ creating a new boot file, deactivating secure virtual memory via Terminal and unse pmset hibernate mode 25. Result is, that I get a resume screen right after chameleon and the an error message "Wake Kernel!" booting with -nowake -wake=yes or -forcewake=yes didn't do any difference. I also checked my memory and did an clean install. I have no idea whats going wrong here. Im happy for any help.
2) brightness control: I read here http://www.insanelymac.com/forum/index. ... opic=87574 that there is a fix to get brightness control working properly. Perhaps you Anastasius could have a look into this and include it in your files?
Thanks a lot!
Geraldo
Geraldo
#111 Post by Geraldo » Tue Dec 13, 2011 7:06 am
It wooooooorks! :banana:
I changed bios config (PCI to auto, extended memory check on boot), disabled motion sensor, also installed sleep enabler and set hibernatemode to 0 and now out of the sudden sleep works.
Yes! Me happy!
jzhang18
#112 Post by jzhang18 » Wed Dec 14, 2011 11:05 am
All files are included in Anastasius' first post. He has done an amazing job in this project!
Just download his 2 zip files, one includes /Extra files(DSDT file is inside). one includes /System/Library/Extensions Kext files.
you won't miss it.
crashnburn
#113 Post by crashnburn » Sat Dec 17, 2011 5:31 pm
Geraldo wrote:It wooooooorks! :banana:
Yes! Me happy!
Do we have to do ALL of the above to get Anastasius files working?
belvederewrx
#114 Post by belvederewrx » Wed Dec 21, 2011 9:15 pm
Gentlemen, glad to hear Lion is up and working on the x61.
So I've got an old version of iatkos v7 installed on my x61 and thought getting L2 would be a walk in the park. (Man was I wrong :P) When installing from USB flash (via a variety of methods) the furthest I manage to get is right before the welcome screen but then my machine reboots. Since I have an OSX install on the same system, is it possible to simply "upgrade" or at least get the bootloader to properly launch the L2 install without rebooting?
Thanks guys
tcone
#115 Post by tcone » Wed Dec 21, 2011 11:08 pm
Geraldo wrote: I tried to fix brightness with the custom x3100 driver which tcone linked to. All it did was wrecking my system. Any other ideas how to fix brightness controls?
I didn't use a patched driver, I took the 10.6.8 driver and patched it myself. It's not a perfect solution and untested on sxga+ (but I could do if I find some time). Brightness is still a bit uneven on xga, worse than on 10.6, but better than without.
This was the only working solution I found for my sxga+ screens for full 1400x1050 support with brightness controll in snow leopard, so I tried this on lion.
I could upload a bash-script snippet or different patched versions of the framebuffer kext the next days if you like to test that (or we could meet at the 28c3 in Berlin).
Too bad this bytecode patch doesn't work with the lion driver and I guess the sl driver is not 100% compatible. :|
mcbrucer
#116 Post by mcbrucer » Fri Dec 30, 2011 6:03 pm
I'm hoping somebody will be able to point me in the right direction with my problems here.
I've managed to get 10.7.2 running on my x61s using the guide but I'm having a couple of problems:
1. no sound
I do see something in the sound control panel but it says 'rear spdif' or something and i get no sound out of the speakers or the headphone socket. I've followed a number of different solutions for this one and got myself nowhere.
2. I can only boot with GraphicsEnabler=No
Have I done soemthing wrong to end up like this?
3. shutdown/reboot dont seem to work.
machine seems to hang up while trying to power cycle.
I'm new to all this hackintosh stuff so am still figuring it all out. Any help anyone can offer will be greatly appreciated.
Cheers
X61s 7666-AA5, 40GB Intel SSD, 2GB ram, Atheros Wifi, OSX 10.7.2
Pirmas
#117 Post by Pirmas » Tue Jan 03, 2012 6:19 pm
I have x61t 7767... Bluetooth worked well before the replacement of extra and SLE files. Now it is just disabled, os does not recognize it at all. how to enable it? thanks
X61T 7767-96U 4GB ram. Lion 10.7.0 OS
victor.vhv
#118 Post by victor.vhv » Tue Jan 03, 2012 6:22 pm
Pirmas wrote:I have x61t 7767... Bluetooth worked well before the replacement of extra and SLE files. Now it is just disabled, os does not recognize it at all. how to enable it? thanks
It worked for me after booting linux / windows and enabling it from there.
Pirmas
#119 Post by Pirmas » Tue Jan 03, 2012 6:59 pm
What about brightness? is it possible to fix the dim to be full screen not just half the screen?
victor.vhv
#120 Post by victor.vhv » Wed Jan 04, 2012 3:41 am
Pirmas wrote:What about brightness? is it possible to fix the dim to be full screen not just half the screen?
I've read some posts about it being possible (check out the earlier ones from tcone).
