8GB RAM Limit
Re: 8GB RAM Limit
Hi Erik,
Generally it is not because of daily use but rather when you need it, and I have seen my RAM at over %60 in certain cases, and mainly I would hope that I could contribute to video graphics more rather than programs because converting AVCHD videos and editing them is a lot slower than I expected it to be on X220. AVCHD manipulation easily takes up almost all of ram since each file is well over GB in some cases. I am wishing now that I went with W series and got 2GB dedicated nVidia, but now I know what my next Thinkpad will have.. Even if it means I will have to give up the very nice 12.5" form factor, which is what I love most about my thinkpad.
8/18/2011 - X220, Intel i5-2540M, 12.5" IPS, FingerPrint, Cam, BT, Intel 6205 Wifi, 8GB, U2312HM Mini Dock Plus 3
1/15/2012 - S405 (Wife's), AMD A6-4455M, 14", 4GB RAM, Windows 8
7/02/2015 - T450s Intel i5-5300U, 14" FHD IPS, FingerPrint, Cam, BT, SSD + M.2, Intel 7265, 12GB
Re: 8GB RAM Limit
I got 2 x 8GB modules yesterday from Ebay, and installed them in my x220, it worked fine, no problem at all, x220 detected 16GB at first boot.hyde wrote:I searched but I couldn't find the reason why X220 has 8GB Ram Limit? I apologize if this was covered, but search results could not get me the answer.
-LD
Ludu35 - San Jose, CA
X220: i7-2620M IPS 16GB Samsung 830 128GB series
Re: 8GB RAM Limit
Yes, I believe it was proven earlier that it can be done, and looked like limit due to non-availability at the time that spec was listed on website. Now we see them cheaper and cheaper.ludu35 wrote:
-LD
Re: 8GB RAM Limit
Yes, this is a common issue when memory standards change. The system manufacturer only posts the limit that they have tested since higher-density modules were not available at release. They tend not to update the original specs/docs after that unfortunately (even after they release BIOS updates specifically mentioning compatibility with higher-density modules).
Current Thinkpads:
bgalakazam
Re: 8GB RAM Limit
Actually at the time of X220 launch 16GB of RAM was already available. I don't know why they opted out. When I bought mine there was only 16GB at 1600MHz or 8GB at 1833MHz aftermarket. Now there is 16GB at 1833 aftermarket, BUT it will run at 1600MHz. I have been running on 16GB since I got my X220 without a problem.jdrou wrote:Yes, this is a common issue when memory standards change. The system manufacturer only posts the limit that they have tested since higher-density modules were not available at release. They tend not to update the original specs/docs after that unfortunately (even after they release BIOS updates specifically mentioning compatibility with higher-density modules).
15" Macbook Pro, T400 for car diagnostics
previous: T60p -> X60 -> T61 QXGA -> X220 -> W510
X1 Carbon (5th gen, 2017) : 8gb Ram or 16gb Ram , i5 or i7
by asterinex » Tue Apr 25, 2017 4:12 am » in ThinkPad X1/X1C - 26 Replies
- 2057 Views
Last post by w0qj
Sat Apr 29, 2017 11:22 am
WTB: A X61 Tablet Motherboard and 8GB of RAM
by LibreKiller » Fri Mar 31, 2017 12:33 am » in Marketplace - Forum Members only - 1 Replies
- 255 Views
Last post by wujstefan
Fri Mar 31, 2017 2:28 am
FS; Dell E7440 / 8gb ram / i5-4300U / 14" FHD touchscreen / 128gb + 320gb
by db999md » Sat Apr 08, 2017 11:02 pm » in Marketplace - Forum Members only - 0 Replies
- 246 Views
Last post by db999md
WTB: 8GB DDR3 SODIMM RAM (2x4GB is fine) for ThinkPad T420
by oeuvre » Tue May 16, 2017 9:44 am » in Marketplace - Forum Members only - 4 Replies
- 253 Views
Last post by oeuvre
Tue May 16, 2017 8:54 pm
