Error 2100: HDD0 (HardDisk Drive) initialization error (2)?
Re: Error 2100: HDD0 (HardDisk Drive) initialization error (2)?
@ajkula66, I'm glad you happened by... I wasn't going to install since that wasn't your instructions. Now, at what point to do I press F12? Thanks
Turn the machine on, press F12 once you see *any* movement on the screen (ThinkPad logo) - might have to press it a couple of times (quickly) until the boot device list is displayed.
Good luck.
Good luck.
@ajkula66, thanks. That's what I did. I pressed F12 as soon as I saw the logo. A message displayed under the Thinkpad logo: "Preparing Boot device list". Nothing happened, and I got the Error again. But I hadn't burned the file as .iso so it didn't work correctly and maybe that's why I got that message (?). But I'll burn it as .iso and press F12.ajkula66 wrote:Turn the machine on, press F12 once you see *any* movement on the screen (ThinkPad logo) - might have to press it a couple of times (quickly) until the boot device list is displayed.
Good luck.
Yep, that sounds right...just make sure it's burned as ISO and you should be good to go...
Good luck.
Good luck.
@ajkula66, thanks. I appreciate the clarification.
Following your suggestion, I:
Which one is CDr?
Should I select 64bit or 32bit?
- selected a download from this list mirrors
- here's the options to select: North America - USA - Linux Freedom
Which one is CDr?
The fourth one on the list is what you need (32-bit CD)...
Anything below 700MB in size will be on a CD - when you see a 800+ MB format it's most likely a DVD.
Good luck.
Good luck.
@ajkula66, thanks. I just looked at the list closer and I see where it indicates cd or dvd. doh!
javier paolini
hlw chris. how are you?
i saw different solution here. But they are too lengthy. But the solution given by the people was very helpful i have to say, well i have faced this kind of problem too, thank god that i got a perfect and easy suggestion from a site, the is is very helpful, i will need this site in future, if your problem is not solved yet, please go to this URL
http://www.techyv.com/questions/error-2 ... s-continue
Hope you will fix your problem
thank you.
thank you.
Detection error 2100 HDD0 not accessible
by CometCKO » Wed Feb 01, 2017 9:46 am » in Thinkpad X6x Series incl. X6x Tablet - 0 Replies
- 1321 Views
Last post by CometCKO
X230T - 2100: Detection error on HDD0
by fultontech » Sun Mar 12, 2017 1:49 pm » in ThinkPad X230 and later Series - 2 Replies
- 559 Views
Last post by Dorin_
Mon Mar 13, 2017 1:21 am
whats the best Hard drive model and Dvd/cd/ internal drive can upgrade W520 quadcore.
by upgrades » Fri Feb 24, 2017 10:42 am » in ThinkPad W500/510/520 and W7x0 Series - 4 Replies
- 1276 Views
Fri Feb 24, 2017 1:00 pm
Hard Drive won't boot and external USB Hard Drive enclosure/caddy/adapter for file retrieval
by E350 » Thu Apr 06, 2017 11:38 am » in ThinkPad T6x Series - 5 Replies
- 925 Views
Thu Apr 06, 2017 9:43 pm
Users browsing this forum: iModFrenzy and 33 guests
