Dell D420 vs. X6x
Dell D420 vs. X6x
Hello, recently I bought at eBay Dell D420 in a good state, with full set of devices (docking, DVD drive, batteries). I use it for my business trips - 1,4 kg is better than 2,7 of my T60p. I find it OK (for its' age), only the hard drive could be slightly faster. Just wondering: has anybody here ever compared D420/D430 with Thinkpads X6x? Weight, size? Performance? Extensibility options? Reliability?
Regards,
Andrey
Regards,
Andrey
- in use -
(1) TP R61i Frankepad - 4 GB / C2D T9500 / 180 GB SSD / UXGA display
(2) Lenovo 3000 N200 - 2 GB / C2D T7300 / 160 GB
(3) TP T450s
- in museum -
IBM 600x, IBM TP T43p, Lenovo TP Z61t, Lenovo TP X60 Tablet
(3) TP T450s
- in museum -
Re: Dell D$20 vs. X6x
Compared with X60 (same generation) D420 would have lower CPU performance because of ULV processor and it uses a 1.8" PATA drive which limits your storage options. 1.8" spinning drives are normally only 4200rpm.
X60 uses far more common 2.5" SATA drives. X61 would be even more powerful with 64-bit CPU.
D420 is also about an inch wider than X60 because of the wider screen. The D420 does have more pixels though at 1280x800 vs. 1024x768.
Current Thinkpads:
X31, X40, X61T, X61, X201, X220 (i7 IPS), W520 (FHD), T440p (FHD),
T480 (QHD)
Dells: Latitude C840, Precision M70, Precision M4400, M6400 (WUXGA), M6600, M6700, 7730, XPS 13
Daily driver: MS Surface Pro 7 (i7)
T480 (QHD)
Re: Dell D420 vs. X6x
Hello jdrou,
thanks for the Response. X60/X61 has better Performance, and what about x60s/x61s? Don't they use the same ULV CPU like D420? Actually, Performance itself bothers me not that much. I use D420 as an "internet-capable" typewriter in Trains, ULV CPU is sufficient for that. Recently I even watched DVD on it. But the 1,8" HDD... it's a real Problem.. If my HDD dies, I have only two Options:
- buy a next (most probably used) one at eBay
or
- use mSATA-to-ZIF Adapter and connect mSATA-drive (SSD, most probably).
Anyway, thanks for the Reply.
Kind regards,
Andrey
or
Kind regards,
Andrey
- in use -
(3) TP T450s
- in museum -
(3) TP T450s
- in museum -
There are 5400rpm 1.8" HDDs for the Dell D420. Search for "1.8 hard D420 5400" on eBay.
Dell Latitude 7370 (QHD+, 2.84lb); HP Pavilion x2 12-b096ms (1920x1280, 3.14lb); Microsoft Surface 3 (1920x1280, 2.00lb);
Dell OptiPlex 5040 SFF (Core i5-6600); Acer ET322QK, T272HUL; Crossover 404K; QNIX QHD2410R; Seiki Pro SM40UNP
Having used a 1.8" HDD on a laptop (modded Acer Aspire One A110), I have to say that it's rather slow.
If you find a ZIF to mSATA/M.2 adapter, grab it and get an SSD.
s-versions and tablet versions used LV processors (15W/17W TDP vs. 9W/10W for ULV) except for one X60T submodel did use ULV Core Solo according to ThinkWiki.BigCatAndy wrote: ↑Wed Jan 17, 2018 5:23 amwhat about x60s/x61s? Don't they use the same ULV CPU like D420?
If you can get some sort of SSD that would probably make much more impact that the faster CPU though.
Current Thinkpads:
T480 (QHD)
T480 (QHD)
That's a good hint, thanks. At the present I have no problems with (slightly longer) boot - when you travel 5 hrs in a train, it doesn't matter if your laptop boots in 40 or 100 seconds. Perhaps, later, when I decide to upgrade him, I would put some mSATA in it.
Thanks a lot for the information and discussion.
Reagrds from Hamburg,
Andrey
- in use -
(3) TP T450s
- in museum -
(3) TP T450s
- in museum -
Dell D420 vs. X6x: Update -> switching to x200s
Hello,BigCatAndy wrote: ↑Wed Jan 17, 2018 6:59 pm
Andrey
I used Dell D420 for 6-7 months, but last week I occasionally found x200s for 50€. I found it a good deal and decided to switch to X200s. So, now I wait for my parcel and will test it as soon as it arrives.
Regards,
BigCatAndy
- in use -
(3) TP T450s
- in museum -
(3) TP T450s
- in museum -
mSATA SSD should do it: https://forum.thinkpads.com/viewtopic.p ... 08#p781708
mSATA SSD should do what?RealBlackStuff wrote: ↑Mon Apr 16, 2018 4:00 ammSATA SSD should do it: https://forum.thinkpads.com/viewtopic.p ... 08#p781708
- in use -
(3) TP T450s
- in museum -
(3) TP T450s
- in museum -
I was showing in that link how to use an mSATA in a 1.8" drive, that's all.
Ah, ok, thanks...RealBlackStuff wrote: ↑Thu Apr 26, 2018 4:57 pmI was showing in that link how to use an mSATA in a 1.8" drive, that's all.
- in use -
(3) TP T450s
- in museum -
(3) TP T450s
- in museum -
- 5 Replies
- 1559 Views
Tue Jan 16, 2024 5:38 pm
- 0 Replies
- 199 Views
Last post by jronald
Fri Mar 22, 2024 7:59 am
FS: Dell (!!!) M6400 Covet, top-end, modded
by wujstefan » Mon May 06, 2024 6:34 am » in Marketplace - Forum Members only - 0 Replies
- 84 Views
Last post by wujstefan
