Digitizer x61t
Digitizer x61t
Hey there hope y'all are well! I've been having a problem with the digitizer on my x61t. When I put my screen into tablet mode I lose my touch responsiveness. Doesn't seem to be a software issue, when I very slowly lower the screen I can keep the digitizer responding but it's a process. I think the hinge is getting worn and loose. I'm a little nervous to replace it. Does anyone have experience replacing those? Or knows whether or not it would help much?
Re: Digitizer x61t
You probably need to replace the LCD cable (which carries the digitizer's signals) as well.
Re: Digitizer x61t
That makes sense, thank you for your help!! I ordered the 93P4507 LCD cable and a hinge today just in case! I am very excited for them to arrive please let me know if anyone has any advice on the disassembly and assembly.
Thanks again!! C:
Thanks again!! C:
Re: Digitizer x61t
Get the illustrated manual from the HMM link above.
