There are two batteries available for the X61 - a small one and a large one.
Does anyone know of any comparison article about them?
Also I'm trying to find part numbers for both to make sure I get the right one.
One advert I've seen shows an item as being compatible with
40Y6999 40Y7001 40Y7003 42T4505 42T4506 42T5224 42T5247 42T5266 92P1163 92P1164 92P116 92P116 7 92P1168
Looking through the HMM for the X61, it isn't easy to lookup which I need.
X61 battery p/n
X61 battery p/n
My ThinkPad Graveyard:
600 * 2, X220, X61 * 2, T61
Re: X61 battery p/n
After looking at the FRU listing at the end of the HMM...
Avoid the batteries listed as Battery 4-cell Li-Ion (Prismatic) because these are only compatible with the X60s and X61s-- these are the slim variants of the X60/61 family, with a battery slot that's slightly wider than the regular model. Regular X61 batteries will fit the slim models with a spacer that's usually included, but the prismatic batteries are physically wider and will only fit the slim models as a result.
The ones listed as Battery 4-cell Li-Ion (2.6AH cylindrical) and Battery 8-cell Li-Ion (5.2AH cylindrical) are compatible with the X61. The 8-cell sticks out from the back, and provide around 3.5 hours of runtime, the 4-cell gives half of that. Knockoff batteries give less, around 3 hours for the 8-cell (based on personal experience).
X61 battery - 40Y7001
by karotlopj » Fri Dec 15, 2023 4:22 am » in Thinkpad X60/X61 Series incl. Tablets - 0 Replies
- 1510 Views
Last post by karotlopj
ThinkPad A22m battery recondioning after battery rebuild
by kfzhu1229 » Mon Dec 11, 2023 5:57 pm » in ThinkPad R, A, G and Z Series - 0 Replies
- 2640 Views
- 4 Replies
- 4920 Views
Tue Dec 19, 2023 12:59 am
Wi-Fi card recommendation for X61
by karotlopj » Thu Dec 14, 2023 4:26 am » in Thinkpad X60/X61 Series incl. Tablets - 14 Replies
- 17141 Views
Tue Jan 23, 2024 6:12 am
