Hi all,
I got a replacement palm rest for my X220 off eBay: it's not original and bare bones, no touch pad.
Transplanting the original touch pad into the new palm rest seems easy enough; it's just the four screws, right?
The new palm rest is also missing the aluminum foil pieces (left & right) and I see the water drainage duct is open, but should be easy to close up -- the original is just some plastic sheet covering that's been stuck on there and is coming loose anyway, so I'll figure something out.
But what's up with the aluminum foil? heat shields?
They're stuck onto the original palm rest, guess they'll be difficult to remove intact and stick on the new one... anyone done this before?
Some suitable replacement tape that I can use instead?
X220 palm rest replacement
T410 2537-9UG | X220 4293-Y16 | X200s 7469-A98 | T400 6474-1AG
Re: X220 palm rest replacement
If I were to venture a guess, it's RF shielding, especially for the WiFi and WWAN cards on the right side.
You could put aluminum foil tape instead, but I don't know how well it would adhere to the plastic surface after many months or years. Just to be safe, I'd put Kapton tape (I read somewhere that the original 3M brand sticks better compared to the cheap ones) over the aluminum tape.
Thanks axur-delmeria,
I see some 3M aluminium tapes here on Amazon, but no Kapton (only other brands).
Think I'll try the former
[sold] IBM Workpad C3 Palm PDA $15
by dizmayed » Mon Jan 29, 2024 7:52 pm » in Marketplace - Forum Members only - 3 Replies
- 896 Views
Last post by H-Atkinson
Sun Feb 04, 2024 11:37 am
Farewell to my X220...
by axur-delmeria » Tue Nov 28, 2023 12:15 am » in ThinkPad X200/X201/X220 and X300/X301 Series - 5 Replies
- 21150 Views
Last post by mikemex
Wed Jan 10, 2024 5:32 pm
Thinkpad X220 the webcam doesn't work but the thinklight does!!
by ned91 » Sat Dec 23, 2023 12:28 pm » in ThinkPad X200/X201/X220 and X300/X301 Series - 1 Replies
- 4184 Views
Last post by nomad1977
Sat Dec 23, 2023 6:33 pm
Thinkpad X220 Tablet Step-By-Step Windows 11 with all Fn key
by nomad1977 » Sat Dec 23, 2023 5:32 pm » in ThinkPad X200/X201/X220 and X300/X301 Series - 3 Replies
- 7369 Views
Sun Dec 24, 2023 5:01 pm
