I recently bought a T420 that had a broken screen (or so I thought). A broken screen was OK for me since I anyhow was about to do some upgrades, including a 1600x900 panel, but also flashing coreboot onto to it and installing an ivy bridge processor.
So I got all the needed parts, flashed coreboot successfully, put everything together (with the new panel)... and still no picture... Now, I was able to verify that the laptop is working (except for the screen) by using an external monitor + Fn&F7 + live Linux image. Also, while in the live session, if I open some bright sharp pictures I am able to see them on the laptop screen if I point the brightest flashlight I got at the screen. So from what I have read on forums this points to a blown backlight fuse.
I opened up the laptop and found the fuse (verified with multimeter that it is blown), but it is tiny and I am not skilled enough to do the replacement, nor can I source the replacement fuse locally (and having it delivered to where I live would be half the price of a replacement motherboard from ebay). So I am thinking of just jumping it.
But before I do, I would like to know the risks of jumping it. If whatever caused the fuse to blow occurs again, what components can I damage? Basically I am OK with killing the motherboard, since that is useless to me anyhow if I get no picture, but the rest (cpu, ram etc...) I would not like to damage. Also, I got a new LCD cable because the old looked splintered/ripped at the screen connector. Maybe that caused the fuse to blow and therefore it should not happen again now that I got a new cable... maybe? Your thoughts?
Blown T420 backlight fuse, potential risks if jumping/briding?
Re: Blown T420 backlight fuse, potential risks if jumping/briding?
Welcome to the Forum.
The most likely blown fuse is either F19 (0.5A, marked F), or F3 (3A, marked P).
Both are described as "fast-acting".
Do NOT bridge a blown fuse, you run the risk of blowing something else!
If you can manage to solder a wire to each end of the fuse on the board, you can then solder a new fuse (of a larger size if you like) between the other ends of the fuse.
Alternative: piggyback-solder the new fuse on top of the old one.
- Contributing Member
On some earlier machines I have soldered a single strand of a 14 gauge stranded wire over the two ends of the fuse. Then a bit of tape to insulate the [censored] fuse assembly.
(It does not like the word Bas tard ized?)
Ron
Ron
T400's and T500's
T400's and T500's
When I blew the backlight fuse (F7) on my T420 I just bridged it with a wire and it seems fine, for now. :\ Can't sell it like this, though.
P71 X330 T60 et al
Lazy jumping cursors on X220 with Debian 11 distro
by N4b00 » Mon Dec 25, 2023 8:01 am » in Linux Questions - 0 Replies
- 7991 Views
Last post by N4b00
T420 backlight
by csakovacs » Thu May 02, 2024 4:37 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 0 Replies
- 151 Views
Last post by csakovacs
- 2259 Views
Last post by DavidGould
Tue Dec 12, 2023 4:17 pm
Lost wireless on t420 - can’t get it back
by Dd777 » Mon Dec 04, 2023 7:10 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 11 Replies
- 5021 Views
Last post by Dd777
Wed Dec 06, 2023 1:39 pm
