Donated Thinkpads / reinstalling OS
The high school where I teach received several Thinkpads from a local university.
The one I'm working on is a t570
All the machines were wiped clean including the recovery partition.
BIOS on them says Preinstalled WIN OS. When I lookup the number it says it WIN 10 Pro
I downloaded Win 10 from the Microsoft site and it installs Win 10 home. How can I install a legal copy of Win 10 Pro?
Re: Donated Thinkpads / reinstalling OS
Is there a product key in the BIOS? (I don't remember now if there is supposed to be one).
Maybe the instructions here will help:
https://softwaregroup.zendesk.com/hc/en ... an-OEM-key
Also this:
https://forums.lenovo.com/t5/Lenovo-All ... =1#3848658
Also this:
If you use a factory recovery it should activate automatically. Otherwise you can pull the OEM key from BIOS using this command from an admin command prompt or powershell terminal:
wmic path SoftwareLicensingService get OA3xOriginalProductKey
You can activate with that key as previously described.
With the machine's serial number you may also be able to go https://pcsupport.lenovo.com/en/us/lenovorecover and sign up to download the OEM restore for your system.
The recovery sets guy
X13Y G3 | T480 with T25 keyboard | T25 | W520 | T601F | T420 | X220
What I do is slightly modify the Windows 10 installer disk after it's created, by creating an EI.CFG text file in the sources directory, with the following contents:
This is how I installed Win 10 Pro on my brother's T460 after installing a new SSD.
[EditionID]
Professional
[Channel]
OEM
[VL]
0
theterminator93 wrote: ↑Wed Dec 29, 2021 4:06 pmIf you use a factory recovery it should activate automatically. Otherwise you can pull the OEM key from BIOS using this command from an admin command prompt or powershell terminal:
Both methods are quite legal and good. I suspect the second one may be slightly less user-intensive.axur-delmeria wrote: ↑Wed Dec 29, 2021 9:40 pmWhat I do is slightly modify the Windows 10 installer disk after it's created, by creating an EI.CFG text file in the sources directory, with the following contents:
This is how I installed Win 10 Pro on my brother's T460 after installing a new SSD.Code: Select all
[EditionID] Professional [Channel] OEM [VL] 0
MadIceTea, Thinkpad Enthusiast
Daily: X250 FHD
Museum: PC110 20MB, X61 T9300 SXGA+ LED
Donated: x2001 AFFS i5-530 (to my alma matter)
Past: 701Cs German, 535/X, 760E/XL, i-series 12/14xx, piano s30, R60e, X60, X61, T60, T61, X200 P8700, X121e
That chicken sure looks funny.
Daily: X250 FHD
Classic ThinkPads installed in IBM System/390 and zSeries mainframes
by ThinkDan » Mon Nov 27, 2023 4:39 pm » in ThinkPad Legacy Hardware - 13 Replies
- 5010 Views
Last post by ThinkDan
Fri Feb 02, 2024 4:18 am
small bug when swapping Thinkpads in advance Dock station 2503
by n2ri » Sat Jan 27, 2024 3:57 am » in ThinkPad W500/W510/W520 and W700/W701 Series - 1 Replies
- 1204 Views
Last post by mikemex
Tue Feb 13, 2024 2:54 am
T580 Compared to Classic Thinkpads and Macbook Pro
by MisterB » Fri Mar 15, 2024 12:51 pm » in ThinkPad T430-T490 / T530-T590 Series - 0 Replies
- 441 Views
Last post by MisterB
Jason Bourne Product placement of ThinkPads
by ThinkPad560X » Thu Mar 28, 2024 3:58 pm » in Off-Topic Stuff - 1 Replies
- 319 Views
Fri Mar 29, 2024 11:35 am
