Back when I used Windows 7, I had a yellow mouse pointer set that I got somewhere in the Internet. Now that I'm using Windows 10, I found that it was easy to lose track of the standard white mouse pointer, probably because of the flat color schemes that Windows 8 and later introduced.
Before trying to find that yellow cursor set again, I checked if Windows had something built-in that had high visibility. What I found was the "Windows Inverted" pointer scheme-- something that I haven't seen since my DOS days more than 20 years ago.
Basically, the pointer color is the inverse of the area its floating on-- it's black when the background is white, blue when the background is red, and orange against the bluish highlights of this forum. That makes the mouse pointer easily stand out no matter where it is in the screen.
The return of the inverted mouse pointer...
Re: The return of the inverted mouse pointer...
I've been using Windows Standard (large) on most systems, which already makes things easier. On a whim, after reading your post, I've decided to give the Windows Inverted (large) scheme a try. Let's see how I like it after ~1 week.
main.cpl FTW!
main.cpl FTW!
I think that in the DOS days, the inverse-color mouse pointer was used in order to reduce RAM usage-- the pointer is generated programmatically (just XOR the color value to get its inverse) as opposed to moving around its bitmap .
FS: IBM mini black PS/2 ball mouse
by ThinkDan » Sat Dec 02, 2023 5:41 am » in Marketplace - Forum Members only - 0 Replies
- 1427 Views
Last post by ThinkDan
Original TrackPoint mouse (?) on ebay UK
by ThinkDan » Mon Dec 04, 2023 10:15 am » in Marketplace - Forum Members only - 0 Replies
- 1565 Views
X230 trackpoint, mouse buttons and some keys still not working after keyboard change
by frog4 » Mon Jan 22, 2024 4:24 pm » in ThinkPad X230-X280 / X390 Series - 2 Replies
- 1824 Views
Last post by frog4
Tue Jan 23, 2024 5:22 am
- 3 Replies
- 930 Views
Fri Mar 29, 2024 11:27 pm
