Fittings
1stallthewayaj
Fittings
Does anybody have any fittings they can sell me for an Aluminum External HDD Enclosure??? I have this Enclosure and an EIDE 20G HDD that I want to rig up for my Thinkpads...... but no USB or Parallell fittings..
A J A
A J A
1stallthewayaj
Fittings
Hi James:
I didnt think Radio Shack would carry such items. I am not worried so much about the USB cable as I am about the fittings in the back that the HDD plugs into, that are for a HDD and not a CDROM Drive.
A J A
A J A
1stallthewayaj
Fittings
James: What you are saying is that, I can take an External CD ROM drive case, and replace the CDROM drive with a HDD.....????
A J A
A J A
Yep! My first USB1.1 external 3.5" HD case was an old Sony Spressa external CD burner in which the CD had died.
I simply replaced the burner with a spare desktop HD and it worked just fine. Painfully slow, but fine.
I've long ago replaced that with a USB2.0 case, but only because USB1.1 was so slow, not because there was any problem getting it to work.
Regards,
James
Regards,
James
James at thinkpads dot com
1stallthewayaj
fittiings
Okay James.... I'll do it!!!
'Preciate it!!!
A J A
'Preciate it!!!
A J A
